Author Topic: MV6 Shocks  (Read 3897 times)
tmx
  • Herefordshire
    • 3.2 MV6 2002
MV6 Shocks
« on: 23 September 2008, 18:36:29 »
MV6s passangers side shock is broken  :( will an 98 Elite one fit or not and how much is one from vx on tc ive missed placed the yellow bible
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: MV6 Shocks
« Reply #1 on: 23 September 2008, 18:44:48 »
Looks like £42.72 +vat each on TC :y
Trade club card holder
Code scanner available
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: MV6 Shocks
« Reply #2 on: 23 September 2008, 18:51:13 »
Thanks Alex cheap :D anyone know aout fitment of them?
markey mark
  • SLady bitshorpe north lincs
Re: MV6 Shocks
« Reply #3 on: 23 September 2008, 18:52:55 »
16mm nut in boot and 21mm bolt at bottom ten min job !  :y
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: MV6 Shocks
« Reply #4 on: 24 September 2008, 16:39:43 »
Front Shocks!!!!!!!!!!!!!!!! not rear ones :(
HerefordElite
  • Hereford
  • Welcome to the Shire
Re: MV6 Shocks
« Reply #5 on: 24 September 2008, 17:27:35 »
not 10 min job then !!!! ;)
« Last Edit: 24 September 2008, 17:27:55 by herefordelite »
Dazzler
  • Haverhill, Suffolk
Re: MV6 Shocks
« Reply #6 on: 24 September 2008, 21:01:08 »
I believe that the Mv6 shocks are a bit shorter than the Elite ones, hence the Mv6 sits a little lower.
MutantCav
  • Gainsborough
Re: MV6 Shocks
« Reply #7 on: 24 September 2008, 21:03:02 »
MV6 shocks are the uprated bit of an MV6 over the rest of the Omega range suspension wise...
« Last Edit: 24 September 2008, 21:04:31 by ShieldOfSteel »
alexandjen
  • The Silver Surfer
Re: MV6 Shocks
« Reply #8 on: 24 September 2008, 21:20:24 »
So do MV6 shocks fit other Omegas? :-/
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
Re: MV6 Shocks
« Reply #9 on: 24 September 2008, 21:23:45 »
yes
alexandjen
  • The Silver Surfer
Re: MV6 Shocks
« Reply #10 on: 24 September 2008, 21:27:30 »
yes
Thanks...are both front and rear shocks shorter than normal?
Re: MV6 Shocks
« Reply #11 on: 24 September 2008, 22:03:07 »
yes
Just the rears iic
JueV6
  • Kent
Re: MV6 Shocks
« Reply #12 on: 24 September 2008, 22:08:19 »
I think it's spring rates on the front and rear, plus the shorter rear dampers and the 17"'s give a slightly lower ride.
Re: MV6 Shocks
« Reply #13 on: 24 September 2008, 22:11:59 »
Pre-facelift MV6 - its the shocks ONLY that lower the rear. Springs are the same throughout the range.
Facelift MV6 - Its shocks and springs
Re: MV6 Shocks
« Reply #14 on: 24 September 2008, 22:40:32 »
Just found a broken drivers side rear spring on my
3.2 elite, and its worse than i first thought as the whole bottom coil near the centre has gone, the back end feels wayward, and i have to put it down to the spring as i have just had 4tires 2 new dampers with self leveling, and a wim set up.
So question is, what springs? Can i fit Mv6 springs and lower the ride hight on the air suspension(some how) i presume this may bottom out sooner though?
Since replacing the rear dampers the fronts now feel softer, so if the rear will work with Mv6 springs and stock sl dampers, i will go with mv6 all round. If that maker sense. Anybody know? Cheers.
Ps was going to start my own thread with this but that seemed abit silly while this has got all your attention. Hope you dont mind?
