Author Topic: Coolant Leak  (Read 1522 times)
colin267
  • Peterborough
Coolant Leak
« on: 19 September 2008, 16:43:27 »
Hi all,  3 weeks ago noticed small coolant loss. Nothing obvious so topped it up and been monitoring since.  Rate of loss suddenly increased over last few days!  Still nothing obvious - no leaks (that I can see) and nothing on ground underneath.  Car running fine - temp gauge fine (80degC ish) - heating/cooling fine.  Had a look through forum - notice that the HBV is a possibilty - is this a good place to start?  Presumably HBV is under scuttle like other models - mine is 2.2 petrol estate.
Many thanks.
Colin
Re: Coolant Leak
« Reply #1 on: 19 September 2008, 16:58:21 »
hbv is good place to start
jimmas
  • stevenage, herts
Re: Coolant Leak
« Reply #2 on: 19 September 2008, 20:24:38 »
if not hbv could be start of head gasket just changed mine with exactly the same symptons, mine was blowing across no 3 cylinder I had no oil in water no overheating only coolant loss, just a thought worth getting checked.
colin267
  • Peterborough
Re: Coolant Leak
« Reply #3 on: 19 September 2008, 21:53:43 »
Guys,
Many thanks for info.
mark readman
Re: Coolant Leak
« Reply #4 on: 19 September 2008, 22:02:52 »
It sounds like you may have the dreaded Head gasket failure, The one that many on here are in denial of, it is a very common fault on the 2.2
first fails around 100k and then around every 30k there after unless you get a complete head skim as part of the repair.
As it increases the emissions light will come on as steam is detected in exhaust gasses.
You need someone with a water tester to diagnose because the first sign is exhaust gasses in the water, basically it draws water in to the cylinder most commonly in to pot 4 hence it is known as pot 4 failure.
I do hope you find a leak !
but it doesn't sound good.
Mine was done at 104k so I opted for a head skim and for the head to be fully part washed to clean the breathers.
It's not the end of the world, but it is a bugger !
And vauxhall deny any manufacturing fault, instead they just harp on about the wrong antifreeze, in the meantime, another bites the dust !
ians
  • Reading
Re: Coolant Leak
« Reply #5 on: 19 September 2008, 22:40:48 »
to be fair, the denial you refer to concerns V6's with failing oil coolers/HBV's etc.   HG failure on 4 pots does seem more common.
colin267
  • Peterborough
Re: Coolant Leak
« Reply #6 on: 24 September 2008, 19:50:41 »
Due to go into local independent garage (he's good & honest!) tomorrow.
Last few days, on startup it's been running rough with considerable clouds of what I assume is water vapour out of the exhaust.  Once warmed up all seems pretty much OK although occasional hesitation. I guess it's looking more & more like a Head Gasket.
colin267
  • Peterborough
Re: Coolant Leak
« Reply #7 on: 26 September 2008, 19:07:15 »
No great surprise - No.4 cylinder leak!
Page created in 0.024 seconds with 16 queries.
