Author Topic: Cruise control  (Read 3062 times)
Kate
  • Cornwall
    • Drives people mad
Cruise control
« on: 25 September 2008, 13:08:21 »
Is it possible to fit cruise control to any mig or does it have to be a particular model/spec?
Thanks for any help! :y
Re: Cruise control
« Reply #1 on: 25 September 2008, 13:14:23 »
Easy enough to fit to any MIG, you just need to source an indicator stalk, actuator and new brake pedal switch
Kate
  • Cornwall
    • Drives people mad
Re: Cruise control
« Reply #2 on: 25 September 2008, 13:15:52 »
Is it a difficult job? :y
sev
Re: Cruise control
« Reply #3 on: 25 September 2008, 13:43:33 »
Kate, in the maintainance guides there is a how-to for pre-facelift cars.
1995 2.5 V6 CDX Saloon
MutantCav
  • Gainsborough
Re: Cruise control
« Reply #4 on: 25 September 2008, 14:25:14 »
Not difficult at all...what year do you have...probably got all you need right here :)
jonathanh
  • coventry
Re: Cruise control
« Reply #5 on: 25 September 2008, 17:58:37 »
It will probably take 1-2 hours with tea breaks to fit.  Absolutely well worth it I would not be without it!
Re: Cruise control
« Reply #6 on: 25 September 2008, 18:38:39 »
And clutch switch, looks like a manual...
Kate
  • Cornwall
    • Drives people mad
Re: Cruise control
« Reply #7 on: 25 September 2008, 23:38:20 »
It's Guy's 99 model saloon.  I would love cruise control but as some of you know I'm kind of useless. :'(
What you think of as easy would be like mastermind for me! ;D
MutantCav
  • Gainsborough
Re: Cruise control
« Reply #8 on: 26 September 2008, 07:14:07 »
Its really very easy to do Kate...bolt on a box to some already existant bolts (3 bolts, 3 nuts) Clip on the lead...remove existing indicator switch and replace with cruise version of switch (undo cowling 4 screws unclip switch at top and bottom and unclip wiring connector then do opposite for fitting) and fit switch under brake and clutch pedal (bit fiddly but easy to do)...can supply pictures with kit no problem :)
Re: Cruise control
« Reply #9 on: 26 September 2008, 08:44:04 »
Its quite easy Kate, just take your time, and try to do it when you don't need car for a day or so to remove that pressure.
Hardest bit, imho, is those pesky brake and clutch switches, that are more awkward that difficult
MutantCav
  • Gainsborough
Re: Cruise control
« Reply #10 on: 26 September 2008, 09:49:05 »
Is there an easy way TB to get the pedal switches out???
hotel21
  • The Kingdom of Fife
Re: Cruise control
« Reply #11 on: 26 September 2008, 10:03:35 »
There is a red plastic lock gubbins that sits around the actuator plunger.  Slide that away from the switch body to where the actuator sits onto the pedal.  This allows the tangs on the side of the switch to be depressed and the switch removed.
I think.....   ;)
MutantCav
  • Gainsborough
Re: Cruise control
« Reply #12 on: 26 September 2008, 10:12:41 »
Ohhhhhh!!! Yeah could see the little tangs that needed to be squeezed together to pushthe switch out...but couldnt work out why they wouldnt depress...
Kate
  • Cornwall
    • Drives people mad
Re: Cruise control
« Reply #13 on: 26 September 2008, 11:02:57 »
Yes it sounds easy! Not! ;D ;D ;D
MutantCav
  • Gainsborough
Re: Cruise control
« Reply #14 on: 26 September 2008, 12:30:13 »
Really is Kate :)
