Author Topic: SPEEDO DONT WORK,WHAT IS A PAPER CLIP TEST !!!!!!!  (Read 3769 times)
Re: SPEEDO DONT WORK,WHAT IS A PAPER CLIP TEST !!!!!!!
« Reply #15 on: 22 September 2008, 21:42:13 »
dont come on at all
Ah!  Put the bulbs back in that the previous scumbag took out then ;)
4397KENNY
  • GRANTHAM
« Reply #16 on: 22 September 2008, 21:44:04 »
were is the abs ecu located
« Reply #17 on: 22 September 2008, 21:44:39 »
Under the Power steering reservoir, and a real bitch to remove
4397KENNY
  • GRANTHAM
« Reply #18 on: 22 September 2008, 21:46:31 »
great cheers for yeah help
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #19 on: 23 September 2008, 14:02:23 »
Have a go with the search facility on "general Help" section for ABS ECU. There are quite a few historical entries with a wealth of info. Including where to get a recon of your unit done, how much it works out at and also how to do the job. You need patience and a selection of tools.
varche
bluepoint
  • Warrington
« Reply #20 on: 27 September 2008, 04:30:46 »
The n/s Rear hub is the speed sensor and the abs would seem to be linked to this problem, I would place on a tech 2 machine and get a reading from there, as playing around changing ecu's jus might get a little pricey.
