Author Topic: SPEEDO DONT WORK,WHAT IS A PAPER CLIP TEST !!!!!!!  (Read 3747 times)
4397KENNY
  • GRANTHAM
« on: 22 September 2008, 20:38:03 »
HI,CAN SOMEBODY HELP JUST BOUGHT A OMEGA CDX 2.5 AUTO (2001 Y REG) ESTATE.AND THE SPEEDO DONT WORK WHEN YOU START CAR UP THE SPEEDO FLICKERS THEN JUST SEATS ON 0.BEEN TO HALFORDS FOR A MANUAL AND THEY GO UPTO TO 1999.AND I HAVE BEEN READING THROUGH SOME OF THE Q WHAT IS A PAPER CLIP TEST,HOW DO YOU DO IT,SORRY FOR BEING THICK
THANKS :-[
Re: SPEEDO DONT WORK,WHAT IS A PAPER CLIP TEST !!!!!!!
« Reply #1 on: 22 September 2008, 20:48:18 »
Paperclip test won't show why speedo not working, but is described in Maintenence Guides section.
For speedo, does power steering work, does ABS work?
4397KENNY
  • GRANTHAM
« Reply #2 on: 22 September 2008, 20:50:18 »
YEAH THEY WORK
« Reply #3 on: 22 September 2008, 20:50:37 »
just a pointer.... CAPITALS is considered shouting, please take your caps lock off.
Thanks
4397KENNY
  • GRANTHAM
« Reply #4 on: 22 September 2008, 20:52:51 »
sorry mate im a newbie  :y
« Reply #5 on: 22 September 2008, 20:53:18 »
no probs, welcome to the forum  :y
« Reply #6 on: 22 September 2008, 20:55:11 »
Any other parts of dash not working? And does the Average Speed on MID seem accurate?  If so, try reseating dash panel, failing that, it points to failed speedo - quite rare though  :-/
ians
  • Reading
« Reply #7 on: 22 September 2008, 21:21:16 »
BTW it is worth getting a Haynes manual as the vast majority of it will apply to your car - its really just the facelift bodywork that will be different. Engine, brakes,suspension etc will be pretty much the same.
4397KENNY
  • GRANTHAM
« Reply #8 on: 22 September 2008, 21:27:18 »
just gone and checked it:abs,tc,c/c dont work.what do you mean by mid
thanks kenny
Mack
    • Audi A6 Le Mans
« Reply #9 on: 22 September 2008, 21:28:33 »
Probably best to check fuses etc.
On my old car a similar thing happened to the rev counter, was diagnosed to a dodgy earth on the back of the dash. I got VX to fix it but I am sure others here will be more help in checking this.....
« Reply #10 on: 22 September 2008, 21:28:56 »
thanks kenny
MID is the display/fuel computer.
Sounds like you ABS ecu has failed, relatively common it would appear on 1998 or later ones...
ians
  • Reading
« Reply #11 on: 22 September 2008, 21:30:09 »
Multi Info Display - its where the clock/trip computer display is.  One of the computer functions is average speed.
4397KENNY
  • GRANTHAM
« Reply #12 on: 22 September 2008, 21:34:25 »
are right no the speed dont show up it reads zero on computer
« Reply #13 on: 22 September 2008, 21:37:35 »
As expected.
Are the ABS or TC lights on?  Do they come on with ign, then go out?
4397KENNY
  • GRANTHAM
« Reply #14 on: 22 September 2008, 21:39:15 »
dont come on at all
Page created in 0.169 seconds with 16 queries.
