Author Topic: Oil leak - back of engine  (Read 908 times)
Martin_1962
« on: 27 September 2008, 15:58:34 »
Just extracted myself, loads of oil over the back of engine by the bell housing.
Just refilling so came in to mention.
I keep the breathers clean so how can it happen?
aghhhhhhhhhhhhhhhhhhhh!!!!!!!!!!!!!!!!!!!11
Martin_1962
Re: Oil leak - back of engine
« Reply #1 on: 27 September 2008, 16:36:14 »
Removed R/H coil pack, oil in back plug >:(
aghhhhhh!!!!!!!!!!!!!1
And my back is in agony
And my rear springs are shot :(
Dazzler
  • Haverhill, Suffolk
« Reply #2 on: 27 September 2008, 16:55:08 »
As are your rear tyres.
Your having a bit of a rough time there Martin.
When these cars are running well you couldnt wish you a better car, but when they start to play up then they certainly do it in style >:(
Best of luck with it all ;)
« Reply #3 on: 27 September 2008, 18:02:44 »
is it worth re torqueing the bolts? I had 3 come loose the other day.
« Reply #4 on: 27 September 2008, 18:33:15 »
Done my 2.0ltr the other day. Same thing, leaking after few days. Cleaned back of engine round dis pack etc re-torqued the bolts. So far, no more leaks. It`s worth a try :)
