Author Topic: Heated seat not working any tips ?  (Read 1085 times)
tampon
  • West London
« on: 29 September 2008, 15:36:40 »
The driver side heated seat doesn't heat up, the dial spins and lights up but no heat, the passenger side one does. Is this a common fault with a easy fix ( fingers crossed )
Fuse ? if so where ?
Loose connection ? where to they connect tot he seat ?
just plain broken, unless it is dead easy to fix I will leave it.
Cheers Guys
Ben
johnnycboy
  • Colchester
Re: Heated seat not working any tips ?
« Reply #1 on: 29 September 2008, 15:53:40 »
seems to be a common fault heated pad packs up.  Unless you can see any connectors adrift, afraid it curtains for you seat.  mines exactly the same.  sorry to be the bearer of bad news. hth
tampon
  • West London
« Reply #2 on: 29 September 2008, 15:55:25 »
No worries, thanks for the response.
I take it the pad is deep in the chair ? not that easy to take it out of the passenger seat and put it into the drivers ?
« Reply #3 on: 29 September 2008, 15:58:16 »
You need to remove upholstery if its cloth, to get to pads.  Pads are around £70 a set I believe.  Not really need on cloth, tbh.
Leather, apparently pads sewn in to leather, so no chance.
tampon
  • West London
« Reply #4 on: 29 September 2008, 16:00:47 »
It is leather buuuuuuuut, I am a upholsterer ( traditional antique furniture, not car interiors ), might try and buy a old drivers seat and have a look at taking that apart to see if it is achievable. Are the seats the same on the prefacelift/post facelift cars ?
« Reply #5 on: 29 September 2008, 16:01:50 »
Early prefacelifts don't have side airbags, and use different pretensioners.
tampon
  • West London
« Reply #6 on: 29 September 2008, 16:07:42 »
But the it should be constructed the same roughly though right, so if I tear that apart and get the pad out of it, I can use that experince to judge if its not to much hassle to get the one out of my seat.
« Reply #7 on: 29 September 2008, 16:25:31 »
Many older leather ones will have failed heaters anyway, so watch out for that.
