Author Topic: where can i get this from  (Read 2246 times)
khatton
  • warrington cheshire
« on: 29 September 2008, 13:23:09 »
anyone know where i can get one of the plastic boxes from the top of the engine mine has one blockage i cant clear on it its the one that says ecotec in white on it its a 2.5 v6
  cheers
Re: where can i get this from
« Reply #1 on: 29 September 2008, 13:27:19 »
Dealer or breaker.  Doubt you'll get a pattern part
khatton
« Reply #2 on: 29 September 2008, 13:30:16 »
tried brakers round here wondered if any one here had one i cant post in the wants section for some reason :y
markey mark
  • SLady bitshorpe north lincs
« Reply #3 on: 29 September 2008, 14:02:54 »
i might have one will check later :y
« Reply #4 on: 29 September 2008, 14:04:50 »
250 posts minimum, as its a combine For Sale and Wanted area, and we've had a bit of trouble in the past.
The Barge Captain
« Reply #5 on: 29 September 2008, 14:22:04 »
It will come apart with care using Uncle Stanley, and looks like this inside
Mine was blocked solid, but once open cleaned out easy enough, and a bit of araldite or silicone sealant to put back together again.
HTH
khatton
« Reply #6 on: 29 September 2008, 14:33:26 »
thanks for having a look to see if you have one and i never thought to take it apart i think it the s bend that must be stuck solid :y
The Barge Captain
« Reply #7 on: 29 September 2008, 16:26:36 »
You do get a lot of build-up in the 2 main passages, and the two tiny orrifices easily block.  Carb cleaner is the stuff to use.
khatton
« Reply #8 on: 29 September 2008, 17:08:13 »
took it apart like the picture above then found out it was the two little holes bunged up which i could have got to if i had seen them not to worry glued it back together now waiting for it to dry you live and learn :-[ :-
