Author Topic: Orange light came on the dash board  (Read 4162 times)
Miggy24
  • Exeter,Devon
« on: 29 September 2008, 15:12:22 »
Hi all on my way home this morning picking the gf up i was going down the motorway and a orange light came on on the dash board.I think its the engine manament light it stayed on a good 4 5 mins till it was safe to pull over.When i did i opened the bonnet and all look as it should be can anyone no wot this can be.I did have all the breather pipes off about 2 weeks back can it have something to do with that
The Cambelt Kid
  • Derby
Re: Orange light came on the dash board
« Reply #1 on: 29 September 2008, 15:19:14 »
Have you done a paperclip test to see if any error codes are stored in ECU?
[size=18]Project LP6 has landed![/size]
[size=12]DIY LPG now finally complete!! Whoo hoo.[/size]
Miggy24
  • Exeter,Devon
« Reply #2 on: 29 September 2008, 15:49:00 »
Ok well i looked at that and tryed it and i dont really understand how it works.The flashes went 2 then 1 then 2 then pause the 3,2,3  tryed counting all of them and got up 2 about 140 odd flashes so i must be doing it wrong any help or tips
« Reply #3 on: 29 September 2008, 15:55:05 »
OK, the 1,2 = 12. Which should repeat 3 times, ie 1,2 small pause 1,2 small pause 1,2
Then a longer pause, then next code flashed out
« Reply #4 on: 29 September 2008, 15:55:38 »
look at the video on my guide, should give you the idea :y
Miggy24
  • Exeter,Devon
« Reply #5 on: 29 September 2008, 16:15:10 »
Right well i did that and i got code 31 what does that mean.I found one that said 31 means no RPM but thats for the v6 and mines only the baby 2.0l 8v
« Reply #6 on: 29 September 2008, 16:26:42 »
Was that the only code except the 12. Or where there others after the 31?
The cycle loops back round to 12 when all codes flashed out, so keep looking until you see the 12 again.
Miggy24
  • Exeter,Devon
« Reply #7 on: 29 September 2008, 16:29:42 »
yeh it did go back to 12
Miggy24
  • Exeter,Devon
« Reply #8 on: 29 September 2008, 16:30:13 »
i`ll try it again just incase lol
Miggy24
  • Exeter,Devon
« Reply #9 on: 29 September 2008, 16:38:16 »
Right i did it again and its doing the same thing again
« Reply #10 on: 29 September 2008, 16:47:31 »
So only codes are 12 and 31?
What did this orange light look like?
Any other symptoms, eg poor perfomance?
Miggy24
  • Exeter,Devon
« Reply #11 on: 29 September 2008, 16:50:38 »
looks like a weird camra its under the handbreak light.well i thought the car fealt abit shakky but the gf said it all seamed fine to her.When doing the paper clip test on the 8v engine does it need to be running
Got code 13 what does this mean
« Last Edit: 29 September 2008, 17:06:12 by devonboy2008 »
prr
  • paignton devon
  • dont be scared to take it apart
« Reply #12 on: 29 September 2008, 22:12:54 »
hi to another miggy owner in the south west try to read the codes again but you have to watch the light the codes run round in a cycle
prr
  • paignton devon
« Reply #13 on: 29 September 2008, 22:25:23 »
if im right its a montronic ecu
code 12 start of test
 code 13 is oxegen sensor no change in voltage/open circuit check wiring no breaks etc
code 31 rpm crankshaft sensor
if it was this the engine would be in limp mode
im sure someone more knowing will coment soon
« Last Edit: 29 September 2008, 22:40:34 by prr »
Miggy24
  • Exeter,Devon
« Reply #14 on: 30 September 2008, 07:39:59 »
thanks prr i`ll try and look at the sencer wires today on my break
Page created in 0.021 seconds with 16 queries.
