Author Topic: is this a sign of torque convertor failure  (Read 1017 times)
shanjon
« on: 30 September 2008, 21:03:15 »
my mother in laws miggy keeps having problems , she keeps getting the automatic gearbox warning in the display and gearbox goes into limp home mode ,
i took it for a spin today and just before it gives warning it accelerates however it fails to change gear and goes into limp mode
if you switch the engine off it is fine again, i have checked the oil levels in the gearbox and they are fine, any ideas
markey mark
  • SLady bitshorpe north lincs
Re: is this a sign of torque convertor failure
« Reply #1 on: 30 September 2008, 21:45:44 »
try oil and filter change first !  :y torque converters very rarely fail !!
« Last Edit: 30 September 2008, 21:46:08 by markey_mark »
« Reply #2 on: 30 September 2008, 21:55:57 »
never heard of a torque convertor failing, get the engine codes read, because an engine fault can cause the gearbox to go into limp mode
Martin_1962
« Reply #3 on: 01 October 2008, 09:17:44 »
Sounds like a selector switch
shanjon
« Reply #4 on: 01 October 2008, 13:04:26 »
i reccomended oil and filter change to the father in law which he is going to do when funds allow,
i did a paperclip test and there are no error codes , im sure we will get to the bottom of it eventually , she is just worried it is gearbox failure
shanjon
« Reply #5 on: 01 October 2008, 13:05:54 »
sorry forgot to mention a small fact,,, it may be irrelevant but it does not play up on motorway , it only does it when you have been slow moving in traffic
Page created in 0.059 seconds with 16 queries.
