Author Topic: HELP please eml on after cam gasket change  (Read 2082 times)
craig
  • north wales/connah's quay
« on: 01 October 2008, 10:59:12 »
Hello everyone :y i changed my camcover gaskets yesterday(followed the how too  ) but when i started the car after reassembling,the eml light is on so i have just done the paperclip test and the only code i am getting is 1-2 7-4-1-2-7-4 so i checked the eml list and it says 74   Mass Air Flow Sensor Voltage High
can you help please as it running like a bag of nails now :'(
any ideas please??how do i rectify this??have i put something back wrong
please HELP!!
cheers
Craig  :y
Re: HELP please eml on after cam gasket change
« Reply #1 on: 01 October 2008, 11:06:42 »
Did you remvoe the MAF at all?
If you did, is it fitted the corrcet way round and the connector etc all ok?
Does it run better with the MAF disconnected
Did you connect the plug leads to teh DIS pack correcty, specificaly the 2-4-6 bank where it is easy to get it wrong!
« Last Edit: 01 October 2008, 11:07:31 by Mark »
craig
« Reply #2 on: 01 October 2008, 11:34:42 »
i didn't touch the maf mate!!
and i didn't remove anything from the dis pack :-/
craig
« Reply #3 on: 01 October 2008, 12:36:54 »
i just disconnected the maf and tried it and its a hell of alot worse without it connected :-/
« Reply #4 on: 01 October 2008, 12:38:37 »
Ok, check for air leaks......brake servi pipe, rubber O rings under the plenum etc
craig
« Reply #5 on: 01 October 2008, 12:46:45 »
when the engine running there is a constant air(hissing)noise sounding like its coming from the back of the plenum ::)is this normal???or could that be the problem?? :-/ :-/
markey mark
  • SLady bitshorpe north lincs
« Reply #6 on: 01 October 2008, 12:53:47 »
sounds like you have dislodged a o ring under plenum bud !!  :(
craig
« Reply #7 on: 01 October 2008, 12:55:48 »
would this put eml on??and could this cause the car to run like it is??? :-/ ::)
markey mark
« Reply #8 on: 01 October 2008, 12:57:43 »
wouldnt nessecery put eml on but would make it run like a bag of spanners ! take plenum off and check all connections and reseat o rings !  :y
craig
« Reply #9 on: 01 October 2008, 13:46:58 »
i just asked the lad from over the road(mechanic)who come over had a quick look  ::) ::)this doesn't help he said as he plugs the camshaft sensor back in for me ::) :-[
thanks for your help ::) :P
Mark dtm and markeymark :y :y :-[ ;D
« Reply #10 on: 01 October 2008, 13:48:54 »
er....that would raise a different code.....
beemerdevil
« Reply #11 on: 01 October 2008, 14:20:03 »
So is it sorted now??
craig
« Reply #12 on: 01 October 2008, 14:28:26 »
it was probably me reading it wrong ::) :-X
cheers Mark :y
craig
« Reply #13 on: 01 October 2008, 14:29:55 »
it seems to be :-[ eml doesn't come on now :y and runs fine ;)
