Author Topic: changing key chips  (Read 2205 times)
george1965
changing key chips
« on: 01 October 2008, 15:32:38 »
i have a immobiliser, have sourced used one with key. how do i ghange the chip from one key to the other and will i have to do anything else to start the car. its omega 2.5 v6, 1998.
« Last Edit: 01 October 2008, 15:35:24 by george1965 »
markey mark
  • SLady bitshorpe north lincs
Re: changing key chips
« Reply #1 on: 01 October 2008, 15:58:32 »
only way to change chip is take to vauxhall dealer or someone with a proper tech2 and you will also need your carpass  :y
« Reply #2 on: 01 October 2008, 16:19:47 »
Engine ECU is tied to immobiliser.  Keys are tied to immobiliser.  So engine ECU, Immobiliser ECU, and transponders in keys all need to be paired up with each other.
What was wrong with original immbiliser>
beemerdevil
« Reply #3 on: 01 October 2008, 16:33:36 »
while we're on the subject of key fobs.......i got my security casd/codes from vauxhall, and had a new fob programmed and now all works well, but i dont want to pay VX megga bukks for another (spare) key - whos the Top Bod for keys on the forum??
« Last Edit: 01 October 2008, 16:34:22 by beemerdevil »
« Reply #4 on: 01 October 2008, 16:35:53 »
near you, Marks DTM Calib, but probably can't get the remote fob bit (try egay)
beemerdevil
« Reply #5 on: 01 October 2008, 16:45:35 »
ah....thats the man - cheers
george1965
« Reply #6 on: 01 October 2008, 16:52:33 »
« Last Edit: 01 October 2008, 16:53:59 by george1965 »
george1965
« Reply #7 on: 01 October 2008, 16:57:22 »
 transponder on steering column was broken, was told by garage i would have to change that plus immobiliser is this true
« Reply #8 on: 01 October 2008, 17:40:52 »
Transponder is in key.  The immobiliser ecu (with its associated pickup) is in steering column.
Forget what the garage are telling you for now.
What are the symptoms?
george1965
« Reply #9 on: 01 October 2008, 18:42:47 »
car would not start but took out battery and charged it, put it back in and after a lot of cranking it started, then it ran perfect for three or four weeks and went out saturday and would not start orange light flashes after i crank it for a while, but the ecu in the steering column has a big crack in the box part of it.
just got it mot'd three weeks ago, bought it secondhand six weeks ago, great car dont wnt to scrap it. HELP
« Reply #10 on: 01 October 2008, 19:24:37 »
If the eml flashes, the engine ecu hasn't seen an acknowledgement from immobiliser.
How many keys do you have?
george1965
« Reply #11 on: 01 October 2008, 20:38:45 »
i only have the one, what about the cracked ecu on the steering should i replace that with the used one i sourced or what should i do
« Reply #12 on: 01 October 2008, 20:44:32 »
where are you?
george1965
« Reply #13 on: 01 October 2008, 22:12:28 »
im in banff, aberdeenshire, scotland. im afraid
« Reply #14 on: 01 October 2008, 22:16:41 »
Hotel21 is in scotland,he has just acquired a tech 2. Its either him or vx dealer. :y
Page created in 0.021 seconds with 16 queries.
