Author Topic: Soft touch switches  (Read 3887 times)
markrl
  • London
Soft touch switches
« on: 29 September 2008, 22:19:31 »
Has anybody found a way to easily remove the soft finish coating on the interior centre switch panel switches? The finish on these things really is a joke in terms of practical durability. Just holding or touching the switch cover is enough to start it peeling making the interior look tatty like an old minicab. Underneath this quick peel finish it seems to have a perfectly good shiny black finish if only you could easily get off the clear rubber yuk that’s been applied over the top. Anybody managed to successfully remove the joke finish?  >:(
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
Re: Soft touch switches
« Reply #1 on: 29 September 2008, 23:38:33 »
if having problems most people replace them with a set of the buttons that dont have the coating on; a 'hard' touch set of switches. these then match the ecc buttons and other bits too.
i have a set spare if you're interested, pm me for details  :y
« Last Edit: 29 September 2008, 23:39:07 by ilovemyelite »
PM with your requests.
MutantCav
  • Gainsborough
« Reply #2 on: 30 September 2008, 09:52:09 »
As said, best way is to replace where possible with the older style buttons that in my opinion looked better anyway and are far more durable!
markrl
  • London
« Reply #3 on: 30 September 2008, 10:35:57 »
Thanks for the replies chaps pm sent to ilovemyelite. This peeling soft touch finish problem seems to have also aflicted Volkswagen who have apparently stopped applying it due to the high number of US warranty claims
Phil B
  • South Wales
« Reply #4 on: 30 September 2008, 14:46:39 »
With mine the whole centre console is peeling too as it has the same finish. Is there a version of this without the coating?
Phil
humbucker
  • Cambridgeshire
« Reply #5 on: 30 September 2008, 20:06:41 »
Phil
which bit do you mean phil? probably got something here that will interest you.
« Last Edit: 30 September 2008, 20:06:53 by ilovemyelite »
Phil B
  • South Wales
« Reply #6 on: 30 September 2008, 20:16:54 »
This little beggar:
humbucker
  • Cambridgeshire
« Reply #7 on: 30 September 2008, 21:31:56 »
ah i see
havent got one of those but i do have a walnut set, not sure if your rotary controls will fit the ecc holes though, i think there was a discussion on here not so long ago about switching fascia...?
« Last Edit: 30 September 2008, 21:32:08 by ilovemyelite »
markrl
  • London
« Reply #8 on: 30 September 2008, 21:40:51 »
Those heater controls are readily available at most of the ebay Omega chop shops (never knew they had the soft touch covering but perhaps it was added to the later models).
Heres one with a free radio
http://cgi.ebay.co.uk/VAUXHALL-OMEGA-RADIO-CODE-HEATER-CONTROLS-ETC-N-REG_W0QQitemZ250275957265QQcmdZViewItem?hash=item250275957265&_trkparms=72%3A1301%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
Phil B
  • South Wales
« Reply #9 on: 30 September 2008, 21:47:34 »
Bit steep that one and I'd have to buy the remaining buttons seperate, thanks though I'll keep looking.
Not too fond of walnut either but thanks for the reply.
If anyone reads this and has one like mine going give me a shout!
Phil
humbucker
  • Cambridgeshire
« Reply #10 on: 30 September 2008, 23:34:11 »
Phil
i think i might have some spare soft touch buttons as well if youre after a straight replacement? pm me with details of which ones youre after and i'll have a look for you  :y
they are a bugger to keep prestine for sure. didnt realise the entire centre console was convered in matt lamination there. whatever possessed them?!
eddie
  • Cardiff
« Reply #11 on: 01 October 2008, 03:17:33 »
The damage would appear to be (mostly) caused by fingernails and rings.
Not what I would call a durable finish.
eddie
« Last Edit: 01 October 2008, 03:18:47 by eddie »
« Reply #12 on: 01 October 2008, 09:13:14 »
Only you can't get a small TC button in old style ;)
Martin_1962
« Reply #13 on: 01 October 2008, 09:17:06 »
eddie
I supposed long fingernails on women, but how would rings do it?
markey mark
  • SLady bitshorpe north lincs
« Reply #14 on: 01 October 2008, 09:30:49 »
you can from a vectra  :y
