Author Topic: Start-up Problem  (Read 1537 times)
Tanveer
  • United Arab Emirates
Start-up Problem
« on: 23 September 2008, 21:42:05 »
Hi
I have first problem with my 2003 3.2. Few days back while fuel was low, engine stopped while running, though the display was showing 15 KM of range. Tried to start but no fire with normal cranking. Thought may be tank is completely drained. Added half a ltr of fuel and it started again. Reached the fuel station about 3 KM away added fuel and next whole day it was running like anything. However next morning it was silent again, no fire normal cranking by battery. Checked error code with my cheap diagnostic tool, but nothing was there except "Catalytic convertor low efficiency" which has been there since long. Suspected fault in fuel pump and and found it was pumping when switched on but no power to fuel tank when cranked and hence no fuel to engine.
Checked the fuse box, but could not find anything. Have no idea now.
Approached dealer and he is giving me an appointment a week later.
Any help please.
Thanks
Re: Start-up Problem
« Reply #1 on: 23 September 2008, 21:46:20 »
Hi
Any help please.
Thanks
Could be very wrong but it just seems simply you ran out of fuel on both occasions.  The "range" can always be slightly out when down to 15km / 10 miles, and putting one half a litre in would be just enough in a miggy to go around the corner with a cold engine! :o :o
Fill it up with 10 litres and then see what happens.  ;) ;)
« Last Edit: 23 September 2008, 21:46:57 by Lizzie_Zoom »
« Reply #2 on: 23 September 2008, 21:51:01 »
No 0335 codes stored when you checked engine codes?
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« Reply #3 on: 23 September 2008, 21:59:54 »
Could check the crank sensor as it may be on it,s way out,
Tanveer
« Reply #4 on: 24 September 2008, 14:18:49 »
No it didn't. Maybe the tool I am using is not accurate.
Lizzie Zoom
I tried with full tank, so running out of fuel shold be out of question.
 Also I checked by diconnecting the fuel pump discharge pipe. As key goes from I to II the discharge nozzle discharges fuel, but as I go from II to III there is no discharge. Priming therefore should also not be a problem. I read from previous posts that faulty crank sensor will not power the pump during cranking. This looks appealing in my case, but I am not getting any code. Can there be any other reason?
Thanks all
Tanveer
SP_3.2
  • Leicester
« Reply #5 on: 24 September 2008, 14:53:24 »
I think that if it is on it,s way out  it may not pull up a code this is what i understand.
Hope that helps
Steve
Omegadoha, Desert Member
  • Doha, Qatar
« Reply #6 on: 24 September 2008, 15:04:52 »
Might be well worth changing the crank sensor. Mine displayed similar symptoms
SP_3.2
  • Leicester
« Reply #7 on: 24 September 2008, 15:27:32 »
I Also had a very similar prob on my old 3.0 , If you update your post with where you are maybe someone would have one  that you could try as they are about £60 + frome vaux and it is best to use GM ones.  :y
Tanveer
« Reply #8 on: 25 September 2008, 20:33:21 »
Thanks. I am from middle east. No option other than dealer's workshop. Shall update on this.
Tanveer
« Reply #9 on: 02 October 2008, 01:30:09 »
You all are smart. It was the crank sensor problem which is fixed and now it is running perfectly as usual. It cost me $150 in total other than one week waiting.
I however lost my confidence in the ELM327 chip based diagnostic tool.
Thank all for prviding help
Tanveer
