Author Topic: EMERGENCY - CAR WONT START  (Read 10446 times)
The Cambelt Kid
  • Derby
Re: EMERGENCY - CAR WONT START
« Reply #15 on: 30 September 2008, 22:35:35 »
Hi Mark,
Would a T2 highlight a crank sensor, or is this sensor a suck it and see?
Cheers
Marc
[size=18]Project LP6 has landed![/size]
[size=12]DIY LPG now finally complete!! Whoo hoo.[/size]
« Reply #16 on: 30 September 2008, 22:37:46 »
It should show it up...
The Cambelt Kid
  • Derby
« Reply #17 on: 30 September 2008, 22:42:15 »
sounds like a good idea if it saves replacing the sensor.  I just hope it's not in a 'good mood' and is working when tested.
Does the crank work on the hall effect? as does the cam sensor?
The Cambelt Kid
  • Derby
« Reply #18 on: 01 October 2008, 09:20:19 »
You'd never guess what - the l**dy car started first time this morning  >:(
Now i think the problem maybe heat related becuase i did take the car for a short spin at about 13:00 yesterday luch and then it failed to start at 17:30.
Would a crank sensor cause intermittent warm start problems?
I'm thinking about buying one today and fitting tonight after work...
Martin_1962
« Reply #19 on: 01 October 2008, 09:21:51 »
YES :y
markey mark
  • SLady bitshorpe north lincs
« Reply #20 on: 01 October 2008, 09:29:48 »
most definatly bud !!  :y
The Cambelt Kid
  • Derby
« Reply #21 on: 01 October 2008, 09:39:05 »
Hallelujah!
Whoo hooo i'll take my chances on a £70 sensor and do it after work (if they have it in stock)  I've seen a pic of a pre-facelift sensor next to the oil filter in the how2 section, so will my facelift be in the same location?  I don't recall seeing it during my recent oil change.
Cheers
Marc (now feeling much happier)
« Reply #22 on: 01 October 2008, 09:55:19 »
pedal trick on 2.6. Press brake and gas pedal to the floor, turn key to position 2 and count the flashes from eml
« Reply #23 on: 01 October 2008, 10:03:03 »
if you get 0335 is crank sensor, ie 10flashes pause 3 flashes pause 3 flashes pause 5 flashes. Dont drive unnecessarily until changed, car could cut out and leave you with no power steering or brake servo
The Cambelt Kid
  • Derby
« Reply #24 on: 01 October 2008, 10:22:24 »
No errors just constant stream of flashes...  but then i did just start it and it ran ok, so maybe the error won't surface.
« Reply #25 on: 01 October 2008, 10:38:36 »
should store the code. Strange one. Any spark issues would show on pedal trick i would have thought. Maybe fuel related? Have you got pressure at the shrader valve on fuel rail? Maybe worth checking next time it plays up?
The Cambelt Kid
  • Derby
« Reply #26 on: 01 October 2008, 11:01:08 »
I did get a few flashy light yesterday but then cranked again and the EML was clear.  Code reader failed to show any errors.
Pressure in fuel rail and pump replaced yesterday in the carpark at work.  Tried to start in LPG and this failed also, although i have never tried this before and am not sure in LPG starts work on my car.
Cheers
« Reply #27 on: 01 October 2008, 11:27:40 »
Cheers
Was this the EML flashing WHILST CRANKING ?? If so it indicates an immobilisor fault ....
I'm wondering ... on my old miggy I had an irregular starting problem .. it was, eventually, traced to the chip in the keyfob being loose, so not "talking" correctly to the chip in the car .. they have to line up accurately I believe... and every time the keys were in my pocket the chip was moving about.  It was solved by the simple superglueing of the chip into the case correctly .. so it no longer moved ....
Might be way off beam but a thought ???   :-/ :-/ :-/
« Reply #28 on: 01 October 2008, 11:35:33 »
YES :y
Agreed..
The Cambelt Kid
  • Derby
« Reply #29 on: 01 October 2008, 11:38:23 »
Hi,
Sorry forget to mention i had foot on gas and clutch pedals to get the EML to light up.  I dont think i got the EML during normal cranking.
Pages: 1 [2] 3 4  All   Go Up
