Author Topic: EMERGENCY - CAR WONT START  (Read 10443 times)
The Cambelt Kid
  • Derby
Re: EMERGENCY - CAR WONT START
« Reply #45 on: 01 October 2008, 21:27:33 »
i tought this was a plenum in place job, but i guess it's coming off then...  im guessing its nr the hbv then?
Cheer
[size=18]Project LP6 has landed![/size]
[size=12]DIY LPG now finally complete!! Whoo hoo.[/size]
markey mark
  • SLady bitshorpe north lincs
« Reply #46 on: 01 October 2008, 21:31:33 »
Cheer
you dont need to remove owt to change crank sensor fella as you look at engine its on right hand side near the dispac back of the passenger head should be clipped to a black mount on the rear lifting lug !  :y
The Cambelt Kid
  • Derby
« Reply #47 on: 01 October 2008, 21:41:04 »
do i have a dispack on mine?  i thought 2.6's didnt have them?  i've looked all over and cant see a thing.
« Reply #48 on: 01 October 2008, 21:43:10 »
Lol, no, the connector is at the back of the passenger head and hangs out near the main connector for the injector loom....if its not been buggered then it will be clipped to a plastic clip on the rear engine mount
« Reply #49 on: 01 October 2008, 21:47:52 »
You're right, fly-by-wire 3.2 & 2.6 cars do not have a DIS pack. You have a coil pack clipped directly onto the top of each bank of 3 plugs.
« Last Edit: 01 October 2008, 21:48:04 by Andy_B »
The Cambelt Kid
  • Derby
« Reply #50 on: 01 October 2008, 22:03:58 »
rather hell, whoever did the crank sensor last time managed to wedge the cable and heat sheild between to small pipes and hise the connector very well.  I just sent 1/2 huggin the gearbox  :D
right back on with the sensor
The Cambelt Kid
  • Derby
« Reply #51 on: 01 October 2008, 22:43:33 »
alright fellas, looks like i'm back in the gang!
Meega failed to start up just before i swapped the sensor and started on key after.  :y
The real crunch test will be tomorrow outside my sons school and when i leave work, so fingers crossed.
I can't that you guys for the top class level of support you have given me.   As i have said before, i could never afford to run/maintain one of these at any garage price, so thanks a million.  :D
  :y :y :y :y :y
The Cambelt Kid
  • Derby
« Reply #52 on: 01 October 2008, 22:51:39 »
Oh and none of the work i did was from the top of the car.  I had my arms wrapped around the gearbox and have cuts all the way up with arms  :'(
Not too sure if i went the wrong way about things but the connector wasn't so easy to locate and unclip.
Maybe it was replaced before i bought the car and Vauxhall made a sh*t job at re-fitting the new one?  It's got a ful stealer history so i can only imagine that Vauxhall did screw it up!  >:(
Martin_1962
« Reply #53 on: 02 October 2008, 09:35:55 »
My old sensoris dangling loose as it is too trapped.
Wired the new one via the brake pipes
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« Reply #54 on: 02 October 2008, 10:11:36 »
Hope all goes well sounds like you have fixed it :y
Well done :y
« Reply #55 on: 02 October 2008, 12:50:17 »
well ive hurd of tree huggers, but engine huggers...yeah, much better :y
The Cambelt Kid
  • Derby
« Reply #56 on: 04 October 2008, 10:30:30 »
LOL... well i think my car quite liked the hour long hug and felt much better for it  :D
She now starts first time, every time.  Just like the goo ol days.
Pages: 1 2 3 [4]  All   Go Up
