Author Topic: omega airbag warning light problem  (Read 1862 times)
per2003
  • wigan, lancs
« on: 02 October 2008, 15:25:47 »
hi all,
hoping someone can help.
i recently replaced the heater fan in my 2000 Omega, to do this i had to remove the passenger airbag. Since the airbag has been put back i have got the airbag warning light coming on continuosly!
Can anyone advise how to reset this warning light??
thanks
paul
Re: omega airbag warning light problem
« Reply #1 on: 02 October 2008, 15:29:16 »
You sure that you reconnected it up properly?
A real or 'cheapo TechII' will be able to read & reset the fault code once thereason for it throwing the fault has been corrected.
Where in the country/world are you?  ;)
If you update your profile, there maybe someone just around the corner who can diagnose for you. :y
per2003
  • wigan, lancs
« Reply #2 on: 02 October 2008, 15:33:56 »
thanks for the reply.
i will re-check the connection first but i'm sure its ok.
i've updated my profile, i'm in wigan. (new to all this!)
« Reply #3 on: 02 October 2008, 15:36:23 »
Ah! A Pie Eater!  :y
You have an OOF neighbour & I just visit to work! ;D  :y  :y
And I also have a 'Cheapo Tech II' that is able to clear the fault once fixed.  :y
per2003
  • wigan, lancs
« Reply #4 on: 02 October 2008, 15:46:33 »
hi,
dont really understand what you mean by OOF neighbour! sorry.
are you offering to help with my problem with your reader?
How much do you charge for this?
thanks
paul
« Reply #5 on: 02 October 2008, 16:07:15 »
The airbag system will detect any interruption to related circuits (even with ignition off) and raise a fault. The only way to avoid this is to disconnect the battery before touching it.
I suspect the system now needs to be reset with a Tech 2 or, possibly a cheapo Tech 2.
per2003
  • wigan, lancs
« Reply #6 on: 02 October 2008, 16:13:09 »
does anyone know if it will be expensive to take the car to a diagnostics garage to have it reset?
will a normal diagnostics garage have one of these Tech 2 machines?
chrisdb
  • Chesterfield
« Reply #7 on: 02 October 2008, 17:17:55 »
This will also happen if you turn on the ignition with the bag unplugged. This happened to me last year and luckliy mu local mechanic reset it with tech 2 for £5...
TC Card, will buy parts for members near by. V6 Camshaft locking kit can rent out to members at club rates.
« Reply #8 on: 02 October 2008, 19:09:44 »
hi,
There is another Omega Oners Forum member who is also a Pie Eater. ;)  ;)
Of course.  :y
How much do you charge for this?......
Nothing,  :y
« Reply #9 on: 02 October 2008, 19:17:31 »
Other garages will have generic code readers, Tech II is generally the preserve of main dealers ..... unless you're a forum member with his own ;)  ;D ..... I had an airbag light on my lads Astra F turned off for £30, ut a dealer is likely to charge you more like £50
per2003
  • wigan, lancs
« Reply #10 on: 02 October 2008, 19:59:19 »
Andy,
I would really like your help, especially as you have a Tech II reader!!!!!!!
Let me know how you can help. I could come to you or vice versa?
Paul.
« Reply #11 on: 03 October 2008, 18:49:25 »
Sorted!
One happy customer!
shyboy
  • Southport, merseyside.
    • Mazda 6
« Reply #12 on: 04 October 2008, 09:41:52 »
Hope you know what your doing, Andy! :D :D
per2003
  • wigan, lancs
« Reply #13 on: 04 October 2008, 12:15:28 »
Thanks Andy,
Very much appreciated!!!!!!!!!!
Paul
« Reply #14 on: 04 October 2008, 13:41:23 »
I wasn't sat behind the steering wheel ...... just incase!  :y
