Author Topic: head gasket  (Read 1351 times)
philby
  • bedfordshire
head gasket
« on: 05 October 2008, 00:27:23 »
hi  how can you tell if the head gasket or cam cover gasket had gone on a 1996 2.0 16 v ???
Timbuk
  • Telford
  • owned a Datsun 120y once!
Re: head gasket
« Reply #1 on: 05 October 2008, 00:38:57 »
Big difference between cam cover and head gasket, whats the symptoms ?
Re: head gasket
« Reply #2 on: 05 October 2008, 00:38:59 »
hg,water in the oil, mayo on dip stick, thin oil, rough running, eml light on, oxygen sensor code when paperclip tested.
Cam c, oil in plug wells, general oil down the side of the engine.
Why wassup?
philby
  • bedfordshire
Re: head gasket
« Reply #3 on: 05 October 2008, 01:21:31 »
hi i got oil in one pug well + water loss and will not tick over keep cutting out
markey mark
  • SLady bitshorpe north lincs
Re: head gasket
« Reply #4 on: 05 October 2008, 01:25:11 »
cam cover gasket and hbv !  :y
philby
  • bedfordshire
Re: head gasket
« Reply #5 on: 05 October 2008, 01:28:31 »
hi   what a hbv and is it a easy jop to do
Re: head gasket
« Reply #6 on: 05 October 2008, 01:33:56 »
Clean breathers throttle body and cam sensor, check hbv is not wet or leaking, but first i would be tempted to change the oil and see if it has any water/thin gravey/mayo/white deposits.
Re: head gasket
« Reply #7 on: 05 October 2008, 01:36:43 »
heater bypass value guide in maintenance section for a v6, same for 4 pot.
philby
  • bedfordshire
Re: head gasket
« Reply #8 on: 05 October 2008, 02:03:53 »
hi will it be best to renew the cam cover 1st and then see how it runs ;D
« Last Edit: 05 October 2008, 02:04:35 by PHILBY »
Re: head gasket
« Reply #9 on: 05 October 2008, 02:16:56 »
Yes you found us out, new cam covers fix all known engine ailments!... Not.  ;)
