Author Topic: key dont turn in ignition...  (Read 4140 times)
f13platform
  • birmingham
  • f13..
« on: 05 October 2008, 15:10:58 »
i cant turn the engine on b'use the key dont turn :'( :'(
i had that problem b4 but key turn after few min but this time i ve
been trying for 40 min and key dont turn
what should i do ? what can i do? :'( :'(
« Last Edit: 05 October 2008, 15:21:10 by f13platform »
Re: key dont turn in ignition...
« Reply #1 on: 05 October 2008, 15:35:12 »
could be worn key/barrel.may need a new one ? :-/
mick-1975
  • nottingham
« Reply #2 on: 05 October 2008, 15:35:29 »
hi i would try wd.40 first thats  what happened to mine and it sorted it out temp..
   but change the barrel as i got married 2 years ago and left my car at my dads ,when i went day after to fetch it and go away  i had the same prob again and to buy new barrel.
  you could go scrap yard and get one off and change the pins inside to match tour key ..
 mick :y
« Reply #3 on: 05 October 2008, 15:39:50 »
..........or they might sell you one with a key,if its from a car which isnt good enough to keep the doors etc and thus needing the whole lockset kept complete.
f13platform
  • birmingham
  • f13..
« Reply #4 on: 05 October 2008, 15:41:48 »
albitz thank u for reply i have 2 key one of them are good
but i dont know maybe i need need key
put wd40 where??
Abiton
« Reply #5 on: 05 October 2008, 15:46:16 »
Frustrating as heck this, we had to get the AA out earlier this year.  :'(
One thing you should try (especially if you've been bashing the back end of the key in frustration), is to insert the key a bit less than completely into the lock barrel.  I guess there's some sort of depth-stop at the end of the barrel that can get bent, allowing the key to go in too far.
Once the AA man had got me 'in' such that I could get the barrel off, it became clear that the key was going in about 2-3mm too far, and so the tumblers of the lock were no longer lining up correctly with the cuts in the key (if pushed in all the way).
The tumblers, and the inside of the barrel, will probably need a bit of fettling ( see http://www.omegaowners.com/forum/YaBB.pl?num=1213353737) if you do manage to get it off.  Replacement is probably a better option if funds allow.  I was too tight for that so a small tyrap around the hilt of the key has been an ongoing solution to the 'key goes in too far' problem.  Fettling of the tumblers isn't too tricky. :y
If you do try to refurb the barrel, take your time, and write down which 'number' tumbler (they're all stamped) goes where down each side of the thing if you take them right out.  Note: if you pull the key out with the barrel out of the lock the tumblers are free to fall out!
Best of luck,
Pete
« Last Edit: 05 October 2008, 15:50:54 by Abiton »
beemerdevil
« Reply #6 on: 05 October 2008, 15:48:51 »
squirt WD40 down the ignition barrell (where you insert key) - this may work temporarily -  it has done for me in the past - good luck
« Last Edit: 05 October 2008, 15:49:49 by beemerdevil »
mick-1975
  • nottingham
« Reply #7 on: 05 October 2008, 15:48:53 »
wd.40 straight down in side the where the key goes , get a small screwdriver to open it up then squert it down inside . :y
Abiton
« Reply #8 on: 05 October 2008, 15:56:01 »
You can buy 3-in-1 oil in an aerosol these days, much better bet.  WD40 is primarily a Water Dispersant, not a lubricant.
f13platform
  • birmingham
  • f13..
« Reply #9 on: 05 October 2008, 16:48:52 »
thank u so much
wd 40 worked .  how long i can live with that ?
mick-1975
  • nottingham
« Reply #10 on: 05 October 2008, 16:52:20 »
glad your up and running , try and look round for a replacement for spare just in case it breaks for good ,,
   :y :y :y
iainb
  • West Midlands
« Reply #11 on: 05 October 2008, 16:56:55 »
If you have lots of keys on the keyring remove them so you minimise the load on the key and lock.
f13platform
  • birmingham
  • f13..
« Reply #12 on: 05 October 2008, 17:13:49 »
ok i ll try to change the BARREL + KEYS
do i have to removw the steering ?
or is there any way to remove the upper cowl bolt with out removing
the steering
« Reply #13 on: 05 October 2008, 17:31:59 »
I think there is a guide in the maintenance section. :y
mick-1975
  • nottingham
« Reply #14 on: 05 October 2008, 17:32:10 »
yes mate i had to remove the steering wheel ,  MAKE SURE U DISCONNECT THE BATTERY AND WAIT A COUPLE OF MINUTES TO DE-ACTIVATE THE AIR BAG ..
  U shall have to turn the key in to position 2 i think and at the end of the barrel,or on the side  there is a small hole put a tiny screwdriver in it ,you should then be able to remove the barrel but take care .
  do not remove your key otherwise the pins shall fall out and then your screwed. :y
