Author Topic: 2.0 stutter on the gas.  (Read 2836 times)
« on: 05 October 2008, 12:35:57 »
as above, makes on differance what revs poodleing in traffic on part throttle no problem. Put your foot down ba b ba b ba up to about 4 and it seems to clear. Cam sensor? Having trouble with paper clip test, will try with thicker wire.
Re: 2.0 stutter on the gas.
« Reply #1 on: 05 October 2008, 13:24:47 »
its a 99 face lift by the way.   paper clip test def not working have just checked the dash warning light bulbs and are working, it has the car symbol with spanner through it but not a peep. The engine symbol comes on but and goes out when paper clip added after ignition is turned on, but no flashing, which light flashes on these?
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #2 on: 05 October 2008, 13:42:02 »
hiya, how did your problem start?
also is it auto or manual?
V8!!!!
« Reply #3 on: 05 October 2008, 13:43:24 »
pretty sure p/clip test wont work on later models.I do recall reading something about pressing pedals in a particular sequence to display the codes,dont know any details,sorry.
A search through the threads might reveal something.  :-/
« Reply #4 on: 05 October 2008, 13:54:58 »
its a  manual,car been running bad for about 5 weeks, not my car its a mates, does not drive badly at all, miss daisy would not notice the problem, its just when you put your foot down it stutters .
Having replaced the dash the radio and display have stopped working. Why does it do that my cid on my car did the same when i fixed the dash lights.
ngrainqey
  • rotherham
« Reply #5 on: 05 October 2008, 13:58:35 »
could be timing a little bit out but doubt that would develop
what are the breathers and throttle body like? might want cleaning out
V8!!!!
« Reply #6 on: 05 October 2008, 13:59:04 »
which model / engine is it chris ?
« Reply #7 on: 05 October 2008, 14:26:51 »
Breathers and t body done about 4 months ago along with cam belt, it a 16v 2.0 petrol.
Just trying to see how the cam sensor comes out to clean it, anybody know to save me buggering about?
iainb
  • West Midlands
« Reply #8 on: 05 October 2008, 14:37:08 »
Just an idea that the plugs are breaking down under load.
  Use to happen lots in the old days
Iain
« Reply #9 on: 05 October 2008, 14:55:35 »
Aux belt off. move cable tray. undo camcover nuts. remove camcover. unplug connector on sensor. remove bolt holding sensor. :y
« Reply #10 on: 05 October 2008, 15:44:38 »
nicve one thankyou guys all done off forf road test. :y
anybody got an idea no the radio annd display prfoblem? not a ppe since i took the dash out. have re conected the plug again to try that but no joy.
Martin_1962
« Reply #11 on: 05 October 2008, 16:26:37 »
Misfiring on gas is usually plugs - what is it like on petrol?
« Reply #12 on: 05 October 2008, 16:35:56 »
by gas i mean accelerator pedal, not lpg ;D ;) let it rev out on a part throttle and its not to bad, but boot it and it stutters like your stamping on and off the pedal.
just claened cam aensor and its a no differant. >:(
« Reply #13 on: 05 October 2008, 17:12:12 »
changed plugs, sorted. the one thing i thought it would not be, wtf do i know.
thanks very much for the help. :y :y :y :y
But how the how the hell do i sort the radio and display?????
Martin_1962
« Reply #14 on: 05 October 2008, 20:26:10 »
Your miss worded header fixed the problem ;D ;D ;D ;D
