Author Topic: Headlight Levelling  (Read 1671 times)
Big Bri
  • Swansea
  • WELSH AND PROUD!
Headlight Levelling
« on: 05 October 2008, 16:59:49 »
I get the message Low Beam Fld/Vision so I replaced the motors and sensors with ones from a car that the headlight levelling is said to be working on, the motors retract back in when the ignition is turned on but i still get the message. Any ideas what could be causing this? Is there an ECU for the headlight levelling?
Thanks.
Omega Elite 3.0 V6 24V Manual
[img name=signat_img_resize]http://i262.photobucket.com/albums/ii103/bloosemore/dadsig-1.jpg[/IMG]
serek
  • huntingdon
    • 3.2 mv6
Re: Headlight Levelling
« Reply #1 on: 05 October 2008, 17:07:01 »
headlights  ECU is located under front wing driver side
 need to unscrew wing
« Reply #2 on: 05 October 2008, 19:34:33 »
.....Any ideas what could be causing this?  .....
One of the level switches on either the front near side wishbone or rear near side radius arm could be fubar'd. A Tech II will tell you what's upsetting the system.
markey mark
  • SLady bitshorpe north lincs
« Reply #3 on: 05 October 2008, 19:37:00 »
dont need to remove wing just the arch liner !
tends to be the sensors on front wishbone also servos in headlight  :y
Big Bri
  • Swansea
  • WELSH AND PROUD!
« Reply #4 on: 05 October 2008, 21:07:12 »
The motors retract when the ignition is turned on so could this just be sensor failure?, could the ones I have just bought also be faulty?
Thanks
« Last Edit: 05 October 2008, 21:08:21 by bigbri »
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #5 on: 05 October 2008, 22:53:10 »
Thanks
Have you checked the sensors on the front and rear nearside suspension arms to see if the link arms are intact as they have a habit of either breaking or popping off ::)
Item 13 in the pic below...........
Trade club card holder
Code scanner available
