Author Topic: 2.0 auto power issue  (Read 1346 times)
gan1503
« on: 05 October 2008, 19:21:06 »
hi all
any idea what would cause my 2.0 16v auto to sometimes feel like its losing power,mostly when pulling off. Hard to explain but makes a strange noise,almost like a sort of popping sound while it does it.If it helps the tick over is uneven,like its hunting a bit.
Any thoughts would be welcome.
Cheers
Forgot to mention theres an oily smell,seems to be a leak but no oil dripping onto ground!
« Last Edit: 05 October 2008, 19:22:30 by gan1503 »
HGV mechanic
  • northamptonshire
  • he just keeps on going,,,
Re: 2.0 auto power issue
« Reply #1 on: 05 October 2008, 20:21:24 »
sounds possibly like an ignition related problem, :-/ try checking the spark plugs, (gap, condition etc) if you have an ohm meter, you could see how much resstance you have in the HT leads, ( 10k ohms to every 30cm of lead)
gan1503
« Reply #2 on: 05 October 2008, 20:36:21 »
cheers for reply,i'm not very technical lol & have a shortage of tools to check :-[
the bloke i got it from said he changed the plugs & leads just before i got it
rickyboy
  • Glasgow
« Reply #3 on: 06 October 2008, 12:05:49 »
Clean breathers, throttle body and most importantly the Idle Control Valve - there is a guide in the maintenance section.  Should sort out your problems.  Not a difficult job.
gan1503
« Reply #4 on: 06 October 2008, 12:46:30 »
Cheers Ricky I'll have a gander at that then,hopefully a novice like me will be able to do it
