Author Topic: Engine cut out under braking  (Read 932 times)
jack68
  • Berkhamsted Hertfordshire
« on: 06 October 2008, 21:36:42 »
Hello, i've been reading this i bought the miggy and now i need your help.  I was travelling south and as i braked going down hill the car cut out.  After a few minutes it started again but a mile or so down the road it cut out again and this was also under braking.  I carried out the brake pedal and accelerator check and got the fault codes 10 4 3 10 and then 10 3 3 5.  Has anyone got any suggestions as having read what they mean i'm none the wiser.  The car is an 02 reg 2.6 automatic.
Re: Engine cut out under braking
« Reply #1 on: 06 October 2008, 21:38:37 »
0335 is crank sensor failing so should be replaced....which will cause the engine to cut out as you have just found
0430 is related to the pre-cats getting tired and is nothing to worry about.
« Last Edit: 06 October 2008, 21:39:10 by Mark »
jack68
« Reply #2 on: 06 October 2008, 21:41:25 »
Cheers is there anywhere on the forum telling a; where the crank sensor is and b; how to change it or should i take it to a garage.
« Reply #3 on: 06 October 2008, 21:49:19 »
jack68
« Reply #4 on: 06 October 2008, 21:54:00 »
As i suspected  you do have all the answers.  I will take a look tomorrow and see what parts i need and then try and have a go myself as it looks not too bad.
