Author Topic: Best HT Leads ??  (Read 1966 times)
Mike_T
  • Trimley Nr Felixstowe
Best HT Leads ??
« on: 06 October 2008, 19:57:13 »
Hi, After looking for the cause of my missfire I found No. 6 plug lead seperated from the plug cap and badly burnt, can you please tell me what the best HT leads are ??
Thanks Mike
achoo81
  • Exmouth Devon
Re: Best HT Leads ??
« Reply #1 on: 06 October 2008, 20:16:20 »
Best leads are the Vauxhall ones, they can be bought seperatley but should be changed in sets,and they are sided on the V6 ie: left bank & right bank but they are not cheap.
« Reply #2 on: 06 October 2008, 20:18:28 »
Its a tough call.
Beware of some, if they say to fit the Vectra then they are tight on an Omega (the plug hole is deeper due to the different cam cover gaskets!)
The originals are made by Beru.....so you could try giving these guys a call as they are a Beru distributor  :y
http://www.eurocarparts.com/
« Last Edit: 06 October 2008, 20:18:56 by Mark »
Mike_T
« Reply #3 on: 06 October 2008, 20:21:35 »
Thanks for that ! I will take your advice and change the lot (Coz she's worth it lol)
Do you think it would have caused any other problems ?
Mike_T
« Reply #4 on: 06 October 2008, 20:28:34 »
Thanks Mark I will give them a try.
Phil
« Reply #5 on: 06 October 2008, 20:30:30 »
I've used these:-
10mm 4 core leads
The only problem is the nearside bank is a bit long, but think thats an issue with all aftermarket sets
Price is fairly cheap compared to Magnecor!!
markey mark
  • SLady bitshorpe north lincs
« Reply #6 on: 06 October 2008, 20:47:57 »
I've used these:-
10mm 4 core leads
I also have a set of these and have found the quialty very good and the fit excellent and loads cheaper than genuine !!  :y :y
tintin
  • South Coast
« Reply #7 on: 06 October 2008, 22:57:43 »
I'm not sure you can actually get beru leads any more as you certainly can not for the 2.0xe. Give AutoVaux a call as they sorted me out big time and their prices beat main dealer to death. Even with trade club AV saved me about £20 :o
Member of the MIGweb South Coast Posse
« Reply #8 on: 06 October 2008, 23:18:00 »
I would never pay vx 200 quid for a set of leads.
Bosch leads can usually be found on feegay for around 45 ,they work fine. :y
Pete Elite
  • Uxbridge, Middlesex
« Reply #9 on: 07 October 2008, 00:07:50 »
  Hi,
     If you take out a membership of the AUTOBAHNSTORMERS which costs £20 anually you can not only get a set of leads from them for £35 inc. delivery which i found to be an excellent fit and quality :y but will supply you with a Trade Card so you can save on future purchases from VX Dealers :).
     HTH,
           Pete.
« Reply #10 on: 07 October 2008, 08:28:17 »
Still listed on the BERU site as available  :y
MutantCav
  • Gainsborough
« Reply #11 on: 07 October 2008, 08:33:56 »
 Hi,
     HTH,
           Pete.
Them being??? (Autobarnstormers themselves?)
Pete Elite
« Reply #12 on: 07 October 2008, 13:22:17 »
 Hi,
     HTH,
           Pete.
   Yep :y.
sev
« Reply #13 on: 07 October 2008, 17:24:04 »
vauxhall parts warehouse made me up a set to OEM spec, and charged around £70.
1995 2.5 V6 CDX Saloon
