Author Topic: Misty windows  (Read 6580 times)
gwa
  • Peterborough
  • Ginger With Attitude
Misty windows
« on: 06 October 2008, 19:39:48 »
This morning (05:15) when I went outside to the car, all windows had dew on the outside which I cleaned off. I got in and the inside was misted up so I started up and put the blowers on full blast with front & rear heated windows. After a few minutes they cleared nicely ...... but after a short while they misted up again and for the next 50 miles I had to have the blowers on to keep the windscreen clear. I know I've got to have the A/C re-gassed, but I checked for leaks and have found none. The carpets are dry cos I cleaned out the tubes (whatever they are called that blocked with leaves). Has anyone got any ideas? what settings should i set the heater controls to? appreciate any help. TIA
If it ain't fun, it ain't worth doin
Re: Misty windows
« Reply #1 on: 06 October 2008, 19:48:08 »
Is pollen filter dry?
Also check exhaust vents - in boot, right hand side, little cubby hole. People fill it with crap which prevents airflow.
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Re: Misty windows
« Reply #2 on: 06 October 2008, 19:50:22 »
I am not sure if you have aircon or climate , I have mine on Auto setting set at approx 22 and have no problems .
 If you have the air con on and turn it off when the windows clear in my experience the windowsw very quicly mist up again  :y
gwa
  • Peterborough
Re: Misty windows
« Reply #3 on: 06 October 2008, 19:59:47 »
Erm... pollen filter? what & where?  :-[.
tyreburner
  • bedlington - northumberland
  • It werent a mig but boy was it fast!!!!! R.I.P
Re: Misty windows
« Reply #4 on: 06 October 2008, 20:05:28 »
In my experience, both of cars and coaches it happens more when windows need a clean ( car i bought saturday does the same and i must clean them but they need to be dry and warm!)
Just a thought!!
Mick
"well at least I'm lucky I don't have all the power in the world so I can't opps everything else up."
achoo81
  • Exmouth Devon
Re: Misty windows
« Reply #5 on: 06 October 2008, 20:06:49 »
It's under the bonnet nearside rear lift the sealing rubber , there is a flap in the scuttle lift it , the filter is under there cost to replace if dirty is around £5.
gwa
  • Peterborough
Re: Misty windows
« Reply #6 on: 06 October 2008, 20:12:18 »
Great, thanks. Off to check now.
gwa
  • Peterborough
Re: Misty windows
« Reply #7 on: 06 October 2008, 20:24:09 »
Well its not easy by torchlight, but it felt dry. When I got back indoors my hand was really black so I presume its dirty. For the sake of a fiver or so I'll just change it, the cars probably never had a replacement.
Would it hurt to whip it out tonight and replace tomorrow PM when I get home from work?
oceansoul
  • Sunbury on Thames - Surrey
Re: Misty windows
« Reply #8 on: 06 October 2008, 20:26:56 »
What exactly does the auto button do, all it seams to do turn the fans up to full :S so i keep mine of the "face" air vents setting.
beemerdevil
Re: Misty windows
« Reply #9 on: 06 October 2008, 20:31:34 »
Would it hurt to whip it out tonight and replace tomorrow PM when I get home from work?[/quote]
been in there this long...another day wont hurt ;D  plus it saves all the crap getting in
« Last Edit: 06 October 2008, 20:36:39 by beemerdevil »
achoo81
  • Exmouth Devon
Re: Misty windows
« Reply #10 on: 06 October 2008, 20:32:17 »
No it wont hurt it's held in with two clips  but BE CAREFUL they are fragile, also while your there have a look in the bottom of the space to make sure the drain in the bottom isn't blocked up with leaves and other crud.
gwa
  • Peterborough
Re: Misty windows
« Reply #11 on: 06 October 2008, 20:35:01 »
The manual says:
Air recirculation system
The a ir recirculation system prevents the
entry of outside air and the air in the
passenger compartment is circulated.
Automatic a ir circulation mode 3
Press button t briefly twice within one
second. t appears on the d isplay .
Air circulation is automatically activated as
soon as the system detects polluting gases
from the outside air. The circuit is
controlled by an air quality sensor.
To deactivate electronic a ir circulation:
press button t again.
At outside temperatures below 5 °C the
duration of the air circulation mode is
limited. This prevents the windows from
misting up. Switch to manual air circulation
as necessary.
Re: Misty windows
« Reply #12 on: 06 October 2008, 20:40:41 »
In your dreams!
Around £11 + VAT tradeclub. Being facelift, it must be the more expensive carbon type, not the cheaper ones for prefacelift.
gwa
  • Peterborough
Re: Misty windows
« Reply #13 on: 06 October 2008, 20:44:47 »
Ah, well that was a few weeks until TheBoy cleaned it out and I hosed it. Thanks for the 'fragile' tip.  :y
gwa
  • Peterborough
Re: Misty windows
« Reply #14 on: 06 October 2008, 20:45:56 »
In your dreams!
£5 or £11 its cheaper than a prang cos I can't see  ;D ;D ;D ;D
Thanks guys
Pages: [1] 2 3 4  All   Go Up
