Author Topic: Starter Motor fried on 2.5 TD Help...  (Read 2791 times)
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
« on: 06 October 2008, 17:30:01 »
Could anyone tell me on how to change the starter on my 2.5 TD (BMW version), the only way I can see is to remove the inlet manifold...
Thanks.
Re: Starter Motor fried on 2.5 TD Help...
« Reply #1 on: 06 October 2008, 18:52:35 »
Thanks.
yup, thats correct.
Really easy job on tractor:
Remove engine plastics/viscous fan/intake.
Remove 4 wires from back of starter (after disconnecting battery, obviously
2 nuts and bolts hold starter on.
And yes, I have done it loads of times.  Even keep a spare in garage ::)
Omegatoy
  • UK
« Reply #2 on: 06 October 2008, 20:06:06 »
swapped one from underneath and didnt disconnect battery!!!! its tight but you have to be gentle and careful but i had a skinny blole who could fit his arm down beside the inlet to put the top starter nut back on, was rather pleased i did it ths way!!! :y
« Reply #3 on: 06 October 2008, 20:30:07 »
A pig on an auto though....
Much, much, much, much, million times much easier to do it from top.
Omegatoy
  • UK
« Reply #4 on: 06 October 2008, 21:28:04 »
it  was on an auto!!! mrs omegatoys first one!!!! :-X
« Reply #5 on: 06 October 2008, 21:35:54 »
Idiot ;D
Why didn't you go from the top?  You know its piss easy then ;)
Talking of piss and intakes off, Mr Omegatoy, I may be after getting your hands dirty ::) - as discussed Friday down pub, I appear to be pissing diesel all over the M40  :-X
unlucky alf
  • worksop, notts
« Reply #6 on: 06 October 2008, 21:41:49 »
ive taken mine off from underneath umpteen times [for obvious reasons],when re-fitting word of advice for the top nut holding the starter in, either get a thin walled plain nut [not locking] & run that up the bolt first & tighten, this allows you to put the locking nut on without having to hold the bolt with a spanner as its a sod to get to, or you can grind off the locking part of the nut so it runs freely up the bolt & do it up tight with a socket & to hell with the locker ;), you could put a spring washer on first if you have one which would help keep it tight, but i didnt so i didnt ;),,,good luck :y
unlucky alf
  • worksop, notts
« Reply #7 on: 06 October 2008, 21:46:58 »
PSYCHOCA, where are you based as it dont say on your profile??
Psychoca
  • Norfolk
« Reply #8 on: 06 October 2008, 22:26:23 »
Thank you all,  I had a mate reckon it would be better to do it from underneath, it took about 2 hours to get the F***ing thing off...  So when I put it back on, I'll be removing the manifold...
Thanks again to you all...
Omegatoy
  • UK
« Reply #9 on: 06 October 2008, 22:27:21 »
Idiot ;D
cos i hate taking the inlet off when i dont have to!!!! :y got to go to bicester sometime this week you "working" from home anytime this week??? :y
osealy
  • dublin
« Reply #10 on: 06 October 2008, 22:31:54 »
The Good Honest A/T guy who changed my tranny after i drove thru a flood when the breather had fallen off. Water inthe atf , reverse was the first to go. He def did it from underneath. The last time I changed the glow plugs I could not bully the manifold off. Had to resort to dexterity.
« Reply #11 on: 06 October 2008, 22:40:20 »
Idiot ;D
The inlet is 10 mins max, if you dont have a stupid viscous on ;)
« Reply #12 on: 06 October 2008, 22:40:58 »
I can take a day off if we have a few days notice...
Omegatoy
  • UK
« Reply #13 on: 06 October 2008, 23:21:17 »
ok poss looking at thursday, if not it will have to be next week as rest of this week is sorting out the track slag ready for the wonders of Marham this sunday!!! :y
« Reply #14 on: 07 October 2008, 19:03:56 »
I'll drop you a text. Still on same number as last year?
