Author Topic: What pressure do you guys run you tyres at ?  (Read 3913 times)
tampon
  • West London
« on: 08 October 2008, 11:20:07 »
Do you ever change them ?
I have a facelift estate, just wondered what you run you pressures at ?
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
Re: What pressure do you guys run you tyres at ?
« Reply #1 on: 08 October 2008, 11:23:08 »
36 psi all round. one of the other members found it too be a good match of handling and MPG
Granted it sounds a tad high, but I get better MPG over the stock settings, a slighty harder ride and after 4000 miles no iffy tire wear
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #2 on: 08 October 2008, 11:29:05 »
Im about the same ... 36 rear and 34 front... mines a saloon though ....   :y
« Last Edit: 08 October 2008, 11:29:37 by Mark38 »
Tafty
  • Liverpool
  • This week I am no longer the owner of a miggy!! :(
« Reply #3 on: 08 October 2008, 11:29:41 »
I use 34psi all round on my saloon. Seems to be ok after 10K
« Reply #4 on: 08 October 2008, 11:41:16 »
used to run 31 all around, tried 36 psi, last couple of tanks after markdtms post.
Got a fraction more out of a tank, maybe 20 miles, but the ride was too hard for my liking. Will drop back down to 31.
« Reply #5 on: 08 October 2008, 16:04:25 »
32 all round but 235 wide tires on a saloon. Dont really want to go much higher, keeps it out of the ditch.
« Reply #6 on: 08 October 2008, 16:12:10 »
I pumped my rears up to 36 when I had a heavy load in it about 6 months ago and forgot to let the pressure out. They started to show signs of overinflation (centre wear) so I think that is a little high for my driving.
You have to remember that what's right for someone who does 90% motorway cruising will not be right for someone who does 90% urban driving. Equally, if you fling it around all the time you'll have different requirememnts to someone who drives sedately.
Add to that the fact that gauges are not generally that accurate...
Best to experiment and find what suits you, I say.
« Reply #7 on: 08 October 2008, 16:34:08 »
Quite so, same goes for the whats the best tires question... Whats best for a sedate high mileage, one set of tires per life time driver, wil very bad for an enthusiastic driver who hates climeing trees, and vice versa. All depends what you want from them...
« Reply #8 on: 08 October 2008, 16:38:45 »
My saloon runs at 32 PSI
« Reply #9 on: 08 October 2008, 19:03:27 »
was using 30-32 psi summer-winter but after Mark DTMs post I increased to 34..
Bandit127
« Reply #10 on: 08 October 2008, 19:04:58 »
235 x 17 - 32 psi all round here too. The rears are down to the wear bars now and they have worn slightly more in the centre. So possibly still a touch too high.
Bandit127
« Reply #11 on: 08 October 2008, 19:06:02 »
What post CEM?
TIA
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #12 on: 08 October 2008, 20:18:54 »
i have my 235x17's at 30/31 seems fine for the wear
V8!!!!
« Reply #13 on: 08 October 2008, 20:27:18 »
35psi all round on my Nankang Ditchfinders,seems to suit me.  :)
chrisdb
  • Chesterfield
« Reply #14 on: 08 October 2008, 20:55:24 »
My saloon is 28.5 front, 31.5 rear. Great mpg. I do lots of motorway driving and the wear is very good.
It's worth getting a decent pressure gauge though because I've come accross so of the automatic ones which are as much as 1psi over.
TC Card, will buy parts for members near by. V6 Camshaft locking kit can rent out to members at club rates.
