Author Topic: keeps dumping water  (Read 1381 times)
magnaman777
keeps dumping water
« on: 09 October 2008, 16:13:20 »
hi my miggy keeps dumping water if i fill her up its fine until i get on the road after 10 mins it just dumps the lot ive tryed filling up with water then leaving her to get to temp and nothing happens anyone help she is porly at the mo hanks
johnnycboy
  • Colchester
Re: keeps dumping water
« Reply #1 on: 09 October 2008, 16:16:57 »
Is there anysigns of leaking, sounds more like HBV if it happens when driving, especially if you have aircon/heat on.  may be worth having a feel round the back of plenum where HBV is situated
magnaman777
« Reply #2 on: 09 October 2008, 16:30:03 »
thanks il give it a go but i dont have aircon
johnnycboy
  • Colchester
« Reply #3 on: 09 October 2008, 16:58:01 »
Still think there should be an HBV for the water to circulate around the heater matrix.  May be wrong though.  Can you update your profile with car etc.  Stops everyone from asking the same question about what you drive.  Thanks :y
ballcock50
  • South Wales
« Reply #4 on: 09 October 2008, 21:24:19 »
Had a similiar prob with my V6's both had same fault. the water pipe at the rear of the off-side head had holed but only seemed to leak when revving the engine if let to warm up at tickover it didn't seem to leak.
« Reply #5 on: 09 October 2008, 21:45:14 »
hbv got to be first place to look, my car on at least its second in 70k, see guide for location and next time it leaks, see if the bottom of it is wet... ;)
http://www.omegaowners.com/forum/YaBB.pl?num=1193594464
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #6 on: 09 October 2008, 21:48:54 »
Update your profile mate then people can see which omega you have, 2.0, 2.2, 2.5 etc :y
Abiton
« Reply #7 on: 09 October 2008, 21:50:02 »
No aircon = no HBV, I do believe.  Ours doesn't have one.  I know 'cos it's never leaked.  :y
rickyboy
  • Glasgow
« Reply #8 on: 10 October 2008, 11:16:00 »
Could be a small hole in the radiator somewhere.  My old volvo used to keep its water until you stopped the car.  The hole would then expand and drop the lot in a one-er!  First thing you need to do is get your head under the car and find out what area it's spilling out from.
