Author Topic: cruise control in omega B 1995  (Read 1875 times)
mindaz
  • IRL , UK
« on: 08 October 2008, 17:36:58 »
can someone explain how does cruise control work?
thanks for answers  [smiley=2vrolijk_08.gif]
« Last Edit: 08 October 2008, 17:42:18 by mindaz »
Vauxhall/0pel 0mega 2.5 , 2002 , CD
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
Re: cruise control in omega B 1995
« Reply #1 on: 08 October 2008, 17:50:49 »
Once over maybe 20mph press the top rear button, this will hold your speed. press it again to go faster, press the top front button to slow down.
Press the bottom button, the brake or clutch will cancel the cruise
Pressing the top front button will bring you back up to speed.
MickAP
  • South Derbyshire
« Reply #2 on: 08 October 2008, 17:55:10 »
Yep as above I've just fitted cruise control to my TD.
Is that the correct one shown in your pic, mine I think was only 2 wire fitting, I may be wrong though.
Mick
« Last Edit: 08 October 2008, 17:55:44 by MickAP »
unlucky alf
  • worksop, notts
« Reply #3 on: 08 October 2008, 20:00:05 »
yup i believe it is a 2 wire unit on diesels, it is on mine but mine is a little older, dont know if it changed on the later ones, the operation of the cruise is covered in the owners handbook if you have one, if you want the explaination of how it works i can dig it out but will take some typing & im a slow typist [2 finger job ;)] :y
MutantCav
  • Gainsborough
« Reply #4 on: 08 October 2008, 23:20:57 »
Wow, never knew that...just thought you pressed the top button to hold speed and bottom to cancel!!!  :o :-/
unlucky alf
  • worksop, notts
« Reply #5 on: 08 October 2008, 23:39:54 »
if youve got a drivers manual TS 1433-A-94 its on page 91 :y
mindaz
  • IRL , UK
« Reply #6 on: 09 October 2008, 08:33:52 »
Mick
this is only photo from somewhere =), my switch is also with 2 wire fitting, today I will test on my omega 2.5TD  :D
mindaz
  • IRL , UK
« Reply #7 on: 09 October 2008, 08:50:11 »
I have borrowed TS 1433-B-96 manual, and I found info about cruise control on page 111
MickAP
  • South Derbyshire
« Reply #8 on: 09 October 2008, 13:49:26 »
Read the manual on this especially the section about the application to the TD. I think without digging the manual out myself states that the front top button (slowing down) is inoperative on the diesel engine, you just press the bottom one to cancel the speed setting, or of course just touching any pedal does the same thing.
Mick
mindaz
  • IRL , UK
« Reply #9 on: 10 October 2008, 06:28:42 »
it's not working, nothing happened  :-/
it must hold my speed, but nothing  :-/
maybe  some diagnostics will help (opel tech or autoboss),and it will show the problem maybe  ::) what do you think?
I checked my switch with cruise control on another omega B TD, and it's working
i think the problem is somewhere deeper in my car, not in switch
unlucky alf
  • worksop, notts
« Reply #10 on: 10 October 2008, 08:26:47 »
cruise only operates above 25mph, then push top front button , it should then work, to resume selected speed push [R], this again only works above 25mph, you should also be able to increase speed in increments of 2mph by pushig whilst in cruise mode, if as you say its not working perhaps you should have a tech done on it or a paperclip test i think brings it up, C,C should show up as O/C [open circuit] without the stalk fitted [cant remember code no], then try with stalk fitted & see if C,C O/C code goes away, i was told by TB that all diesels are "plug & play" on cruise, mine worked o,k & mine is a 95 td,
the only thing i can think of is that perhaps the ecu has been changed at sometime by vx & cruise was left from the programming of it, but im only guessing.
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #11 on: 10 October 2008, 11:22:48 »
I know on petrol models i had to have it activated by the Tech 2 machine by Vx .... not sure if its the same with the tractors though  :-/
