Author Topic: Plug connection under rear seat, n/s  (Read 1568 times)
Hoffi
  • Bucks
« on: 10 October 2008, 12:28:17 »
Came accross this a while ago but didn't get to ask: As I have removed my rear seat for cleaning I found three wiring connectors under the left part of the seat from which two (square format) seemed to fit together, the third one (flat) I guess is for rear seat heating which I don't have.
As I have the board computer telling me that I have an headlight vision issue I was wondering if that might be related to that.
So before just plugging the connectors together I first want to check that I am not messing anything up. And also good to know what that wiring is for.
BTW: Can anybody recommend a workshop manual? Don't mind if it is a disk or a book, just want to have something usable.
Again: Thanks for your replies!
« Last Edit: 10 October 2008, 14:28:07 by The_Hoffi »
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: Plug connection under rear seat, n/s
« Reply #1 on: 10 October 2008, 13:27:02 »
get a haynes manual! lol
im not sure about the rear heated seat cables as i dont think mine has them.... without knowing i'd suggest either... cd changer cable, arial amp cable and then obviously heated seat cable- hope that helps
« Last Edit: 10 October 2008, 13:27:36 by grainqey »
V8!!!!
Hoffi
  • Bucks
« Reply #2 on: 10 October 2008, 19:39:45 »
@ngrainqey: Is the Haynes manual of use?
Thanks for your suggestion. As I have some work to be done on my Meggy tomorrow I will check if both connectors fit and than plug them together and see what is happening. Try and error!  ;)
