Author Topic: V reg MV6..... anything i should know about them?  (Read 1730 times)
tintin
  • South Coast
« on: 07 October 2008, 00:30:42 »
Do the old gals have any unpleasant characteristics that need close supervision on, maybe known faults that jump out and bite you on the butt?
Member of the MIGweb South Coast Posse
MutantCav
  • Gainsborough
Re: V reg MV6..... anything i should know about them?
« Reply #1 on: 07 October 2008, 08:40:13 »
Most important part is to keep them well maintained...regular oil changes, and keep the breather system clear or cam covers will leak...
markey mark
  • SLady bitshorpe north lincs
« Reply #2 on: 07 October 2008, 08:47:38 »
cambelt and tensioners every 40k or 4 years max  :y
bappy
  • HAVANT, Hants
  • Don't fart on the leather upholstery!
« Reply #3 on: 07 October 2008, 13:13:22 »
Anything you should know?
only that once you have owned one nothing else will ever seem good enough :D
If at first you dont succeed, Rev it harder!
tintin
  • South Coast
« Reply #4 on: 07 October 2008, 20:12:34 »
So as long as the breathers are clear and the oil is maintained they are pretty much bomb proof then, cool. Cambelt's i do every other year as a rule any way. Had one snap once and have had nightmares about it ever since. My theropist says i'll be fine as long as i take procautions in the future :-/
Bandit127
« Reply #5 on: 07 October 2008, 20:32:39 »
A slow water leak is alomst certainly the Heater Bypass Valve (HBV), no matter what you think, your mechanic thinks or the Haynes manual says.
It WILL go rusty, usually at the tops and bottoms of the doors.
If you have 'soap' in your oil filler cap, it is much more likely to be the oil cooler than the headgasket. Vx mechanics seem to go straight for the HG - at a £600 expense.
The suspnsion alignment is critical - get the camber set as well as the tracking or you will eat 235 x 45 x 17" (i.e. expensive) tyres.
After that - the good news is you have a great motor that drives really well, goes like stink and eats motorway miles at least as well as the best in class. And the MV6 handles too.
Congratulations and enjoy  :y
« Reply #6 on: 07 October 2008, 20:39:00 »
crank sensors fail.  paperclip it regularly, checking for fault codes.
Peter H
  • Somerset
« Reply #7 on: 07 October 2008, 20:41:31 »
I presume all of this applies to '99 MY Elite also...
Bread and water can so easily be tea and toast!
« Reply #8 on: 07 October 2008, 23:33:17 »
Vx mechanics seem to go straight for the HG - at a £600 expense.  .....
And the rest! I have the print out from the previous ower of my car for head gaskets when the car was only 14 months old - it's a 99 T reg. £1400!!!!!!!!!!!!  :o
Albatross
  • Bedford
  • An LSD & an S2000!
« Reply #9 on: 08 October 2008, 08:21:41 »
Yep, although they don't handle quite the same.
Peter H
  • Somerset
« Reply #10 on: 11 October 2008, 14:46:26 »
That's true, but they are comfy! ;)
