Author Topic: Removing 'phone holder' trim ?  (Read 1598 times)
kevpuk
  • Poole
« on: 11 October 2008, 12:42:06 »
My Omega came with a protusion on the passenger side of the centre console, with a phone holder on it....and a power cable snakes out from the bottom of the centre console (where dashboard part meets floor part)......any ideas on how to tidily remove this - I am assuming it is a relatively common fitment, seems to match the rest of the trim etc.
Just don't want to be pulling bits I shouldn't whilst looking for how it is held together, assuming someone here has already done similar ?
    • 530D M Sport, 330i Coupe
Re: Removing 'phone holder' trim ?
« Reply #1 on: 11 October 2008, 13:50:09 »
Can you post a picture? Would help to identify what's what!
kevpuk
  • Poole
« Reply #2 on: 11 October 2008, 18:01:06 »
Here you go....shamelessley snaffled from the Autotrader ad that alerted me to the car ;)
« Reply #3 on: 11 October 2008, 18:09:13 »
SWMBO's Asra had a similar phone holder. IIRC it had a plastic 'blade' that slotted in between the 'wooden' dash and the grey console. The belt & brace bit was a sticky pad onto where you have the 'wood' too.
« Reply #4 on: 11 October 2008, 18:15:19 »
Have a look here if you need to remove front panel :)
http://www.omegaowners.com/forum/YaBB.pl?num=1152745540
kevpuk
  • Poole
« Reply #5 on: 11 October 2008, 18:20:34 »
Definitely it has the 'blade' between fake wood and grey plastic.....just not so sure on how the other end attaches.....down by/behind the glovebox
« Reply #6 on: 11 October 2008, 18:25:33 »
In mine, if I look up under the glovebox to the right I can see the "telematics" box ( if that`s what it`s called :D) You should be able to trace the connection from there :)
Clouseau
  • Telford
  • Keeping the dream alive...
« Reply #7 on: 11 October 2008, 20:01:24 »
Hey Kev
If you are able to remove it without damaging it and were going to bin it, can I have it? :-?
kevpuk
  • Poole
« Reply #8 on: 11 October 2008, 21:45:14 »
Sure, assuming it all comes off in good nick etc - will let you know :)
