Author Topic: Handbrake  (Read 1966 times)
Albatross
  • Bedford
  • An LSD & an S2000!
Handbrake
« on: 11 October 2008, 12:44:59 »
My handbrake lever pulls all the way up and still doesn't hold the car that well.
Is this likely to be a cable problem or shoes?
I have some new shoes on their way from James which I am going to fit anyway.
If it is cable related, what are my options? Can I tension it and, if so, how?
Thanks
Nathan
« Last Edit: 11 October 2008, 12:46:18 by Albatross »
chartz
  • Burgundy
Re: Handbrake
« Reply #1 on: 11 October 2008, 13:02:19 »
Another Omega disease...
Mine does the same !
Any advice welcome then !
Re: Handbrake
« Reply #2 on: 11 October 2008, 13:20:23 »
I knew there was a reason that Marks DTM did that excellent guide in Maintenence Guides section, just so everyone can ignore it ;)
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: Handbrake
« Reply #3 on: 11 October 2008, 13:50:04 »
Here you go guys.....................
http://www.omegaowners.com/forum/YaBB.pl?num=1152564750
Trade club card holder
Code scanner available
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: Handbrake
« Reply #4 on: 11 October 2008, 14:30:52 »
lol you can cheat and adjust it on the auto adjuster which is behind the rear disc- it's a nice way of adjusting them independantly- worked for me
V8!!!!
Re: Handbrake
« Reply #5 on: 11 October 2008, 18:59:36 »
Do it as per the guide, there is no other way to properly do it.
Re: Handbrake
« Reply #6 on: 11 October 2008, 19:06:11 »
Indeed, as I proved to myself today with all stripped down, reassembled and adjusted. :y :y
 No short cuts are possible is my opinion for what it is worth! ::) ::) ::) ::)
Re: Handbrake
« Reply #7 on: 11 October 2008, 19:06:33 »
maybe change the shoes and see if that helps, youll have to readjust when fitting anyway iirc  ;)
monza789
Re: Handbrake
« Reply #8 on: 11 October 2008, 22:50:32 »
hi...mine did the same......the adjusters can be done at the wheels however its a short term fix if mine was anything to go by....the cable may be stretched .
I had the cables replaced ...if i remember they cost about £26 from autovaux in wakefield.
It cost about 20 quid to fit by my local mobile mechanic.
monza
Pete Elite
  • Uxbridge, Middlesex
Re: Handbrake
« Reply #9 on: 12 October 2008, 00:07:49 »
        ;D ;D ;D
Albatross
  • Bedford
Re: Handbrake
« Reply #10 on: 12 October 2008, 07:49:48 »
        ;D ;D ;D
;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
I asked for a diagnosis, not just a how to. Not that funny really. Just a bit sarcy TBH.
« Last Edit: 12 October 2008, 10:13:30 by Albatross »
Re: Handbrake
« Reply #11 on: 12 October 2008, 09:00:20 »
Until handbrake is checked and properly adjusted, its impossible to do any diags ;)
Clouseau
  • Telford
  • Keeping the dream alive...
Re: Handbrake
« Reply #12 on: 12 October 2008, 16:30:38 »
Did this job myself this afternoon.  Handbrake was hitting the armrest to get it to hold the car, so needed doing.
DId it as per the guide but I found that I didn't need to disturb the heatshields to access the handbrake cable adjuster bolt - a 13mm ratchet spanner was perfect and easy to reach with the shield bent down a few cms.
Getting those shoes springs back on again was a bit of a trial though, but the long-nosed pliers and spanner method overcame in the end!
I found that the inside pads on each side were pretty well seized, so it was worthwhile just to get these cleaned up, filed and re-greased. Made quite a difference back on the road.
