Author Topic: pas pump...  (Read 1314 times)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
pas pump...
« on: 12 October 2008, 19:22:58 »
hiya, im just unsure where abouts the second threaded hole on the pas pump is, i know theres one ontop but is the other on the rear or what? and also can anybody help me with what route the pas fluid takes such as.. steering rack, up the pipe to the reservoir, to the pas pump out the other side of the pas pump and then back to the steering rack (that was as an example as i dont know)
thanks
V8!!!!
Re: pas pump...
« Reply #1 on: 12 October 2008, 19:38:50 »
thanks
Funny you should mention pas pumps, I just changed mine today for the one Marky Mark supplied me with (so far I think it's  [smiley=thumbup.gif] [smiley=thumbup.gif]
On mine, there's a clearance hole top & bottom and a threaded hole at around 9 o'clock that another bracket bolts to. As far as the route the ATF takes ....... er? it just does ::) I know it doesn't go to the rack though .... an Omega has a steering box. ;D  ;D  ;D  :y
ngrainqey
  • rotherham
Re: pas pump...
« Reply #2 on: 12 October 2008, 19:51:45 »
thanks
lol thats what i meant...
it comes from the steering box upto the reservoir i think and then there's another pipe that comes up from under the battery area i dont get what goes between in what order if that makes sense
thanks
V8!!!!
Re: pas pump...
« Reply #3 on: 12 October 2008, 20:13:59 »
There's a pipe with a proper union on from the box and then a rubber hose with Jubilees links the pump to the reservoir. I know there's half a paving stones worth of ATF in the hose!  ::)  ;D  ;D
« Last Edit: 12 October 2008, 20:14:11 by Andy_B »
ngrainqey
  • rotherham
Re: pas pump...
« Reply #4 on: 12 October 2008, 20:47:38 »
i wonder how you know that!
i got this carpet under the car pi$$ wet through draining the radiator lol and then got some atf on it too!
V8!!!!
less
  • Hemel Hempstead
    • 2.6 auto saloon
Re: pas pump...
« Reply #5 on: 12 October 2008, 20:56:49 »
Don't forget the insignificant but bl**dy annoying bit that goes up the sleeve or down the neck  >:( ;D ;D ;D
