Author Topic: Windscreen washers  (Read 1079 times)
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Windscreen washers
« on: 13 October 2008, 11:48:18 »
I had been having problems with my washer jets blocking up and the washer water smelling bad recently  .
 So yesterday  I decided to investigate looking at the manuel it spoke of taking the front bumper off to get to the washer bottle so I had been putting it off for ages .
 But if the bottle does not need to be taken out its a simple job after taking the grille off ,you can reach the pump etc no problem .
I pulled the pump out of the bottle and found the inlet a bit blocked with slimey build up  :-/ I then found that the rubber mount the pump fits in too is actually a filter which was also blocked partialyso had that out and cleaned it .
 Another thing I found out was that there is a low level warning sensor in the side of the bottle which was not working so pulled this out too cleaned it up gave it a tap or too and it started working again suspect the contacts had stuck .
While the pump and switch were out I flushed the bottle with clean water to remove anything left in there .
Put it all back together and refilled .
I added half of a sterilising tablet in to the bottle to give it a bit of a clean .
Result the washer jets seem much stronger and hopefully wont keep blocking up ,oh and the nasty smell  has gone too  :y
Re: Windscreen washers
« Reply #1 on: 13 October 2008, 11:55:23 »
The slimey "gunge" that builds up is, usually, one of two things ....
1) If only water is used .. its is algae growth - usually green/brown/black, easily moved by rubbing/scrubbing
2) If cheap/soapy additives are used - washing up liquid being the worst - it is a soap residue as soaps do not actually dissolve in water, but remain in suspension and eventually "settle" where they can.
Answer ??? Use a "proper" windscreen additive mixed at the "correct" ratio .. adding extra to try and get a "better" clean is pointless and makes things worse !!
HTH   ;) ;) ;)
« Last Edit: 13 October 2008, 11:55:47 by entwood »
« Reply #2 on: 13 October 2008, 12:14:51 »
LFF64, as has been suggested, you are not using a strong enough screen wash mix.
If you had headlight washers, this white stuff blocks the extender bits, which are £55 + VAT a pop.  Needless to say, I learned my lesson early on ;D
LFF64
  • HADDENHAM BUCKS
« Reply #3 on: 13 October 2008, 12:45:53 »
I do use addative never washing up liquid and I usually top them up with soft water from work it stops the white streaks on the window when it dries I suspect the build up is from over the years who knows what was used in there in the past
« Reply #4 on: 13 October 2008, 12:50:33 »
Beware of cheap screen wash also.....the comma stuff seems very bad yet the Vx stuff (on trade club) seems excellent
« Reply #5 on: 13 October 2008, 13:14:31 »
The Holts stuff from Costco (dark green) seems to be OK as well, and cheaper than Vx :)
