Author Topic: help!!!!!!!!!  (Read 1761 times)
monkeyboy1
  • Aylesbury Bucks
help!!!!!!!!!
« on: 13 October 2008, 20:17:22 »
Can any one out there help????? I changed my DIS pack today on my 1999 2.0l CD as the engine was very lumpy and struggling at times and upon closer inspection found that the DIS pack was actually arcing with the rear of the engine as there was a crack in it..
Any way changed the dis pack today and all seemed fine, started straight away and no more arcing however when i revved the engine through the range it still feels and sounds a bit rough betwwen two and a half and four thousand revs.
Took her for test run and she seemed perfect accelerating through the whole range whithout missing a beat, however I noticed the temp gauge was still on the rest after half an hour of running and that my front windows would not go up or down with one push of the button it now needs to be held. Could all this be related???????
when i got home revved her again and its still doing the same thing?????????
Any ideas would be appreciated.
Cheers Lee
Timbuk
  • Telford
  • owned a Datsun 120y once!
Re: help!!!!!!!!!
« Reply #1 on: 13 October 2008, 20:20:57 »
Try resetting the windows to start with, take it you had the battery disconnected
monkeyboy1
  • Aylesbury Bucks
Re: help!!!!!!!!!
« Reply #2 on: 13 October 2008, 20:22:44 »
Yes I did.
I thought I read somewhere about resetting the windows??? gonna a sound like a biff now !!! How is that done?
Timbuk
  • Telford
Re: help!!!!!!!!!
« Reply #3 on: 13 October 2008, 20:24:46 »
Yes I did.
see here
http://www.omegaowners.com/forum/YaBB.pl?num=1152602030
rickyboy
  • Glasgow
Re: help!!!!!!!!!
« Reply #4 on: 13 October 2008, 20:30:26 »
Just press the windows up button for about five seconds and they'll work again.  Do it for each window.
Sounds like you've knocked the wire off from the temp sensor which is right next to the dispack.  That's why your guage is not working.  I'll find a picture to give you an idea where and how to put it back on...
monkeyboy1
  • Aylesbury Bucks
Re: help!!!!!!!!!
« Reply #5 on: 13 October 2008, 20:30:56 »
Thanks very much Timbuk, just done it windows now working as normal, thats one down just a few more to go!!!!!!!!!! ;D ;D
monkeyboy1
  • Aylesbury Bucks
Re: help!!!!!!!!!
« Reply #6 on: 13 October 2008, 20:32:06 »
Thank you Rickyboy that would be very helpful ;D ;D
rickyboy
  • Glasgow
Re: help!!!!!!!!!
« Reply #7 on: 13 October 2008, 20:35:22 »
monkeyboy1
  • Aylesbury Bucks
Re: help!!!!!!!!!
« Reply #8 on: 13 October 2008, 20:42:55 »
Thanks Rickyboy most helpful. ;D ;D
rickyboy
  • Glasgow
Re: help!!!!!!!!!
« Reply #9 on: 13 October 2008, 20:45:28 »
No probs!  :)
MutantCav
  • Gainsborough
Re: help!!!!!!!!!
« Reply #10 on: 13 October 2008, 21:02:51 »
Sunroof will need resetting too...
monkeyboy1
  • Aylesbury Bucks
Re: help!!!!!!!!!
« Reply #11 on: 13 October 2008, 21:23:17 »
Cheers but doesn,t have sunroof. aircon only thanks anyway ;D
