Author Topic: Help with codes please!  (Read 1864 times)
« on: 13 October 2008, 14:31:22 »
Help Required please!!
Just reassembled everything after replacing the cam cover gaskets and cleaning out all the oil breather system.
Engine started ok and ran without trouble for about 10 minutes, with just a little smoke from spilt oil burning off.
Went for a test run, and within 3 minutes the engine management light came on.  Paperclip test gave 12, 17, & 73.
What is wrong please??
PS also seem to have a plastic pipe floating around at the back of the engine, around the HBV and oil breather pipes, with seemingly nothing to connect it to! ::) ::) ::)
Is this usual; is there a end of a pipe that has nothing to attach to?  It is about 3/8ths" round with no sign of it ever being connected (the end is in mint condition) with no marks of even a jubilee clip or use. ::)
 Everything else has been connected to all available outlets / inlets!
I now feel out of my depth and pretty miserable! :'( :'(   I am not as good at mechanics on these modern cars as I used to be; oh for a man in my life who can sort things out! ::) ::) ::)
« Last Edit: 13 October 2008, 14:42:22 by Lizzie_Zoom »
Re: Help with codes please!
« Reply #1 on: 13 October 2008, 14:42:09 »
73maf and 17knock sensor. 12 diagnostic start.
« Reply #2 on: 13 October 2008, 14:43:15 »
Which means please Chris?  :-? :-?  ie what do I need to do?
EDIT :  Are these codes right for a 2.5 V6? :-?
« Last Edit: 13 October 2008, 14:47:27 by Lizzie_Zoom »
« Reply #3 on: 13 October 2008, 15:01:28 »
yes,2.5  listed under paper clip test in maintenance section bottom of page 1. Maf is on the air intake, follow air box pipe to engine, first thing in line is the maf. Look for electrical connector unplugged. Or damaged wiring to it. Knock sensor i beleive is favourite for getting trapped when doing cam covers. I have never had problem with knock sensor so dont know where it is.
 Basically you need to re trace your steps and make sure everything is plugged back in and no wires are trapped in the cam covers. Hope helps. :-)
« Reply #4 on: 13 October 2008, 15:11:48 »
12 - Start of code sequence - Ignore
17 - Knock Signal Circuit 2 - Check the state of the knock sensor cable on the passenger side bank. You will notice in the guide how we tell you to be careful not to trap the cable under the cam cover. The cable is near the cam sensor on the front of no 4 cam (by the battery. Make sure it is pluged in to the main loom by where the large branch of cables to the ECU splits off
73 - Maf Voltage low - This sudgests a vac leak or similar so check the likes of the main brake servo pipe and large breathers for security but, concentrate on the 17 first as this can be fl
The extra large pipe sounds like the slush box breather pipe...and should connect to nothing.
« Last Edit: 13 October 2008, 17:10:14 by Mark »
« Reply #5 on: 13 October 2008, 15:19:24 »
Go for the 17 - you may have damaged kncok sensor cable, easily done, and quite common. Cable can be repaired.
MAF fault may disappear once knock sensor fixed, it sometimes throws an erroneous code.  If not, look for airleaks, particularly under plenum area, or vac pipes not plugged back in.
Loose pipe sounds like auto breather
« Reply #6 on: 13 October 2008, 17:14:49 »
Thanks all for your help and it looks as though I will be back under the bonnet tomorrow looking for what I have got wrong ::) ::), trapped or haven't plugged in!! ::) ::) ::) ::)
At least I think I know now what to dive in and look for, which has helped me no end!! :y :y :y :y :y :y :y :y :y
rickyboy
  • Glasgow
« Reply #7 on: 13 October 2008, 17:37:51 »
I'd say airleak, probably the loose pipe that's floating about?  I get knock sensor codes on mine when my lpg mixture is too lean and the MAF code could also suggest the same.
Don't know the layout of the v6 engine so can't help where the pipe is from.  If you can get a photo uploaded I'm sure someone will know where it's meant to go.
« Reply #8 on: 13 October 2008, 17:52:00 »
As already said, thanks for all this, but can I ask one more favour?
Can you post pictures of the potentially offended components, like knock sensor and the cam sensor etc?  The guides I have been studying do not seem to clearly indicate which ones these are (for me anyway!! ::) ::) ::))
I am an old fashioned mechanic who is still getting used to these new fangled cars and don't know what the hell I am looking at if it is not a regular thing, ie like fuel pump!! ::) ::) ::) ::) ::) ;D ;D ;)
Thanks for your help again Mark, and any help all others can give me further on this!! :y :y :y :y :y :y :y
« Last Edit: 13 October 2008, 17:52:40 by Lizzie_Zoom »
JasonH
« Reply #9 on: 13 October 2008, 21:18:52 »
No pics but the knock sensor wire tucks in round the front corner of the cam cover (near the battery) and plugs in just on that corner - very easy to leave unplugged.
« Reply #10 on: 13 October 2008, 21:23:00 »
Thanks for that Jason, will be out looking tomorrow!! :y :y
« Reply #11 on: 14 October 2008, 09:06:37 »
I must be going soft in my old age!
The connector for the knock sensor is indicated by No 2 and the wire clips and runs as shown by No 1
« Reply #12 on: 14 October 2008, 10:31:40 »
Many thanks Mark! :y :y
