Author Topic: Not the best day I've had  (Read 2361 times)
johnnycboy
  • Colchester
« on: 09 October 2008, 16:06:00 »
 Just had the second hand AR35 box fitted (Tuesday) not done 20 mile and a part of the side came out dumping ATF all over the carriageway, subsequently. >:( cheapo Tech 2 says incorrect gear ratio.  Any ideas what this spring thing with a black plastic cap is, sits near enough next the exhaust - only know that cause RAC man says that stopped it from falling out.  Unfortunately can't take any photos as the car has been towed to garage to examine the extent of damage.
Re: Not the best day I've had
« Reply #1 on: 09 October 2008, 16:11:45 »
Gutted for you Johnny... Incidentally, have you found someone reliable for ATF changes? I don't fancy doing it myself as it's not a good thing to do at the side of the road!
johnnycboy
  • Colchester
« Reply #2 on: 09 October 2008, 16:15:04 »
Garage I use in colchester is transmission specialist - charged me £117.50 for gaskets & fluid change.  He's a reliable guy, may be a bit pricey but no problems with the change.
This car has had more ATF changes in the past month than I've had hot dinners and looks like another AR35 is going to the great scrapyard in the sky.  Getting really pissed off with this motor >:(.  Beacon boy I want my saloon back :P
« Reply #3 on: 09 October 2008, 16:20:56 »
What side is this black plastic cap....what is the box history?
johnnycboy
  • Colchester
« Reply #4 on: 09 October 2008, 16:24:13 »
Drivers side think it may have had a met cap on it before but not there now.  Box history 100000 miles, vehicle service history. thats about it
« Reply #5 on: 09 October 2008, 16:30:38 »
I'm not saying anything... But... ::) :-X
johnnycboy
  • Colchester
Re: Not the best day I've had (AR35 Dropped its load)
« Reply #6 on: 09 October 2008, 17:52:04 »
Do these boxes have a pressure relief valve?  And what pressure should they run at.
sassanach
  • trowbridge
« Reply #7 on: 09 October 2008, 18:08:45 »
that black plastic "thingy"sounds like the 4th gear accumulator cover.about 55mm dia and has a spring under it, held in with a circlip. pressure valve is built in to the pump.
unlucky alf
  • worksop, notts
« Reply #8 on: 09 October 2008, 18:16:06 »
hi johnny, i cant think what part you are talking about, ive had more bad luck with AR35`s than anybody else im sure but cant recall seeing what you describe, i had an oil pump go after a week,which in turn damaged the end of the t/c so i couldnt get it off the box, changed box again & got almighty oil leak, box out again & removed & fitted new oil seal & ive still got a little leak, anyhow you are going to need another box by the sounds of things, but as someone said to me youll laugh about it afterwards, & by me typing that i think your response to it will be the same [2 words, the 2nd one is off!], anyhow i hope this g/box had some sort of warranty even though it was 2nd hand, good luck with it matey you really have my sympathy :'(
johnnycboy
  • Colchester
« Reply #9 on: 09 October 2008, 18:17:42 »
Sassanach - Thats exactly what it is any reason why this would fall out and is it repairable.  TIA
sassanach
  • trowbridge
« Reply #10 on: 09 October 2008, 18:20:41 »
if all the parts were held in place by the exhaust then all you need is the circlip.
johnnycboy
  • Colchester
« Reply #11 on: 09 October 2008, 18:23:50 »
PM sent
MutantCav
  • Gainsborough
« Reply #12 on: 09 October 2008, 18:31:06 »
Tim you think your unlucky but at least you got 25 miles and it lasted a week! lol
Poor Johnnys lasted 15 miles and 3 days! Hopefully its something simple, are these circlips prone to coming off then?
johnnycboy
  • Colchester
« Reply #13 on: 09 October 2008, 18:31:31 »
Exactly ;D ;D ;D ;D
johnnycboy
  • Colchester
« Reply #14 on: 09 October 2008, 18:45:58 »
Thanks for the info Sassanach. :y
