Author Topic: Starting issue's  (Read 913 times)
Starting issue's
« on: 14 October 2008, 20:03:53 »
Mrs. has had starting troubles with the car, it turns over fine then just stops before starting. After about 2 tries it starts up a bit lumpy but once running its' fine have had new plugs and leads recently, this is only the second time it's done it but it's done it now twice in the space of a week.
Any idea's cheers Liam.
Re: Starting issue's
« Reply #1 on: 14 October 2008, 20:12:59 »
Dodgy crank sensor maybe. Paperclip test :question
« Reply #2 on: 14 October 2008, 21:05:06 »
Ok will try one when I get the time, cheers m8.
« Reply #3 on: 15 October 2008, 02:06:26 »
so, if i read correctly, the starter motor turns and seems to pause just before engine fires and runs poorly for a second of 2 ? Sounds like battery running out of juice to me, when it plays up has the car been stood/unused for a while?
« Reply #4 on: 15 October 2008, 17:00:55 »
Nope, did it after shopping and also did it after being sat for about an hour. Hope it's not the battery because that will be I think about the 4th in just over a year, had a new alternator in april too. Yeah you read correctly too  :y
« Last Edit: 15 October 2008, 17:01:20 by LSG_1 »
