Author Topic: Cat woes....  (Read 1545 times)
ST230
  • west sussex
Cat woes....
« on: 14 October 2008, 19:31:50 »
would a blocked cat attribute to poor running issues?????
Re: Cat woes....
« Reply #1 on: 14 October 2008, 19:33:53 »
Any blockage in the exhaust gas flow will cause problems, IMHO it's unlikely to be the cats do the the way they are constructed .. more likely to be the back box which has a great tendency to split internally and send loads of wadding out the back .. looks like horsehair/wirewool .. :(
This can even cause eml warnings as the gas flow is so badly disrupted . :(
This happened on the old 2.5 .. new exhaust and everything was back to normal . :y :y :y
« Last Edit: 14 October 2008, 19:36:05 by entwood »
iainb
  • West Midlands
Re: Cat woes....
« Reply #2 on: 14 October 2008, 19:48:51 »
Simple answer is yes.
But miggys have there own qwerks,with blocked breathers that can lead to rough running and oil leaks.
Please update you profile so we can see what car you have and where you are.
Re: Cat woes....
« Reply #3 on: 14 October 2008, 20:04:45 »
Cats cant be blocked easy..But other parts of exhaust do..As Entwood said..
Bandit127
Re: Cat woes....
« Reply #4 on: 14 October 2008, 20:45:29 »
I have been a member of:
Ford Cougar Forum
Audi Forum
Scooby Forum
OOF.
I must have read tens of thousands of posts. I have not once read a thread where a cat got actually got blocked. In fact, the only time I have heard of it was a Cataclean advert on selly telly....
If you are worried about your cats - leave it in third for a blast at 80 on the motorway for 10 miles a few times. The chemistry of cats makes them self cleaning - they just need lots of heat to work (more than 600°C)
Phil B
  • South Wales
Re: Cat woes....
« Reply #5 on: 14 October 2008, 23:03:13 »
I had a blocked cat once in my mk5 escort. Half the honeycomb broke free and rotated 90 degrees  :-[
All those bl@@dy speed humps they peppered the roads with through keele uni!  >:(
Re: Cat woes....
« Reply #6 on: 15 October 2008, 01:22:21 »
funny you should say that - my mate Mike had a blocked cat on his escort, same reason.
I once had a cat fall apart and become blocked on a Pug 406 1.8 Estate. At the time I was only around 19 and didn't have much of a clue about such things, so I ended up paying £350 or so at ATS for a pattern cat :'(
So far the Omega ones have been reliable for me, it's usually the cat back exhaust system that rots first....
« Last Edit: 15 October 2008, 01:23:21 by JamesV6CDX »
ST230
  • west sussex
Re: Cat woes....
« Reply #7 on: 15 October 2008, 20:38:07 »
profile updated.
it is the V reg 2.0 auto that is running like a bag of ..........
anyone who can help wins a beer.
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: Cat woes....
« Reply #8 on: 15 October 2008, 21:01:07 »
profile updated.
lol might be worth spraying some carb cleaner into the idle control valve.. there's a small airway that gets blocked and causes the bad idling problems
V8!!!!
iainb
  • West Midlands
Re: Cat woes....
« Reply #9 on: 15 October 2008, 21:04:09 »
Maf sensor and idle valve.Might be on to a winner  :)
ST230
  • west sussex
Re: Cat woes....
« Reply #10 on: 16 October 2008, 19:29:21 »
right.....
the car is running like a dream now....
the number 3 lead was arcing out somewhere....
swapped it and all is well now.
thanks for all your suggestions guys.
 :D
