oil filter.
Started by manny, 17 October 2008, 19:03:53
manny
Can anyone tell me the socket size i will need to remove the cannister type oil filter on my 2.6?Thanks :y
2001 OMEGA MV6
QuoteCan anyone tell me the socket size i will need to remove the cannister type oil filter on my 2.6?Thanks :y
Good question, as I found 22mm was just loose on the 'nut' and 21mm was too small.  In theory mine seems to be 21.5mm!! ::) ::)
I resorted to an adjustable spanner, then I discover the central square hole is a perfect fit for a 3/8" socket drive, so I used that! :D ;)
manny
Thanks for the advice. :y
2001 OMEGA MV6
QuoteThanks for the advice. :y
Carefull if you use the 3/8" drive. It's been known to break the aly casting if someone has overtightened it in the past.
willyboy
In the past to make sockets fit tight I have managed by either wrapping electric tape round head or stuck some inside the socket then tapped it on  .. :y
