Author Topic: V6 fitted with Crank sensor from a SAAB??!!  (Read 1938 times)
Varche
  • middle of Andalucia
    • Golf Estate
« on: 16 October 2008, 16:31:47 »
My day was going so well until...
I thought I would get a spare crank sensor (see my other thread)
The part on mine is definitely Bosch 0261210. That isn't either of the recognised V6 part numbers.
2.5V6 Petrol Earlier Models  90492006
2.5V6 Petrol Later Models    90492061
A search on EBay came up with this S/H item
http://cgi.ebay.co.uk/SAAB-9000-CS-CD-CRANK-POSITION-SENSOR-0261210_W0QQitemZ320308625674QQcmdZViewItem?hash=item320308625674&_trkparms=72%3A1301%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
Well imagine my surprise.  :o At what point in the cars life did it get this?
It was one owner from new VX when we bought it and until I found OOF it was only ever in VX dealers for work. However OOfers with good memories will remember that despite being a Network Q car when we got it it had had bulbs e.g. EML taken out of the dash. So much for paying a bit more to buy an original car . I wonder what else there is lurking?
Now ever since I joined the forum I have been convinced that the car is "gutless". It can pull a caravan but has no acceleration. Could this crank sensor be the reason?
I have cleaned it up as it was pretty manky looking at the end and thankfully the car still runs.
How do I go about please getting the right one for the car or should I not bother?
The ever ready to be amazed varche
 ;D ;D
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: V6 fitted with Crank sensor from a SAAB??!!
« Reply #1 on: 16 October 2008, 16:41:54 »
varche i think they are all bosch m8y from my memory when i changed my 3.0 v6s it was a bosch one in there and there is no mention of a replacement in my cars history either until i changed it!
woodsy_mv6
  • West Sussex
« Reply #2 on: 16 October 2008, 17:02:18 »
Don't expect the part to be any different.
Do expect it to be invariably more expensive!
From the moment I picked up your book until I laid it down, I was convulsed with laughter. Some day I intend reading it.
Mike Collins
  • North of Bristol
« Reply #3 on: 16 October 2008, 17:58:48 »
If you look at the plastic mouldings on many parts you will find SAAB stamped on them. All part of GM, some SAABs use the Vectra floor pan I believe.
Varche
    • Golf Estate
« Reply #4 on: 16 October 2008, 18:07:42 »
I haven't got an issue with the badging of parts per se, but I was hoping that someone might be able to confirm or otherwise that the crank sensor is the correct one for the car and advise on the correct GM replacement part.
Is Bosch GM part no 0261210 the same as one of the two GM 90492006  or 90492061 ? Is my late 97 car a later engine?
varche
manny
  • bromorough.Wirral.
« Reply #5 on: 16 October 2008, 18:15:43 »
Ive worked in vauxhalls astra plant where they made the v6 engine.That engine is the same one that goes in the saab.Only diff is the plenum i think?
2001 OMEGA MV6
ballcock50
  • South Wales
« Reply #6 on: 17 October 2008, 22:47:41 »
I think the only difference in the two GM parts are the plugs on the end, one is male the other female i had to trim the outer casing off one to make it fit my early V6.
