Author Topic: What to do next  (Read 1366 times)
fatboyfat
  • leeds
What to do next
« on: 17 October 2008, 15:29:44 »
Hi all,got the exhaust ordered from eternalcar get fitted next week.I can do an oil/filter change,air filter and probably coolant change,what would you experts recommend that I should also,if anything,do as regards benefitting the health of my carcash is tight after car and exhaust so don't want to do stuff that could wait but want to do things that will be of benefit now,if you know what i mean.I know from receipts that cam belt was done 2 years agfo and 25,000milesThanks
God only created a few perfect men
The rest he gave them hair
Alex Wood
  • Greenhithe, Kent
Re: What to do next
« Reply #1 on: 17 October 2008, 15:50:41 »
Do you know when the spark plugs and fuel filter were last done? I let mine do their 40k and the car definitely felt a bit more eager when I changed them. To be fair they had been fitted since 2002 as the previous owner didn't do many miles. 40k for me is a year and a bit so I'm letting everything run to its scheduled interval except oil and filter, they get done every 3k.
Oh, and if you haven't got leaky cam covers yet you could blank off the EGR valve before it lets too much gunge into your breathers, then you might never have to change the cam cover gaskets! Sure there's a few posts on here about how to do that but basically cut a coke can to the shape of the gasket sandwiched in between the two halves of the EGR.
Another job that might be worth doing soon is the auto box fluid, filter and gaskets. Well worth keeping the gearbox happy on these.
ians
  • Reading
Re: What to do next
« Reply #2 on: 17 October 2008, 16:10:48 »
Clean the breathers - costs nowt (well, some carb cleaner) and will save your camcovers.
also the drain on the passenger side (next to the pollen filter) - check its clear.
Are the doors cracking (sound) when you open them?  Replace the little white washer for 20p
Alex Wood
  • Greenhithe, Kent
Re: What to do next
« Reply #3 on: 17 October 2008, 17:55:13 »
Oo, what washer is that? Mine aren't but might do it anyway.
Bandit127
Re: What to do next
« Reply #4 on: 17 October 2008, 18:20:43 »
fatboyfat
  • leeds
Re: What to do next
« Reply #5 on: 17 October 2008, 22:51:27 »
Thanks for the info guys.I checked out maintainance guides but was unsure what needed doing first.I will be doing oil/filter change this weekend,checked oil level and the previous owners,who thought the blown exhaust was  because the car was powerful with a throaty growl,appear to have stuck half the middle easts oil production in it.Will this have blown crankcase oil seals and are the breathers worth doing now because I can't do seals this weekend,how hard are they to do?.
Re: What to do next
« Reply #6 on: 17 October 2008, 23:20:50 »
They are still worth doing, and yes they are straightforward to do!! :y
Indeed they are easier to do than replacing the cam cover gaskets, which you will end up doing if you do not clean out the oil breather system. ::) ::)
« Last Edit: 17 October 2008, 23:22:21 by Lizzie_Zoom »
