Author Topic: how do i drain the fluid out of auto box  (Read 2911 times)
kris9128
« on: 18 October 2008, 11:52:40 »
this mite seem like a daft question but........
how do i drain the fluid out of my auto box. there is no drain srew.
Re: how do i drain the fluid out of auto box
« Reply #1 on: 18 October 2008, 12:18:39 »
remove both sumps...wear a hat ;D
markfree
« Reply #2 on: 18 October 2008, 13:32:02 »
You could try syphoning the oil out with some plastic tubing or use a syphon pump - a few going on ebay for about a tenner - either way it's pretty messy :-/
Welung666
« Reply #3 on: 18 October 2008, 13:36:57 »
You'd have thunk those clever folks at VX would have designed a drain plug into the sumps really  :-? Are the sumps steel? Maybe able to braze a scrappy found sump drain plug in  ::)
chrisdb
  • Chesterfield
« Reply #4 on: 18 October 2008, 13:52:04 »
Probably a good idea to take off the sump 'cos then you can also check the state of the filter.
TC Card, will buy parts for members near by. V6 Camshaft locking kit can rent out to members at club rates.
« Reply #5 on: 18 October 2008, 15:43:07 »
You'd have thunk those clever folks at VX would have designed a drain plug into the sumps really  :-? ....
You'd have also thought that the same clever bu66ers at Vauxhall could've put a filler tube in the engine bay while they were at it!  :(
v6coop
  • Nottingham
« Reply #6 on: 18 October 2008, 15:52:55 »
Did BMW fit a drain plug when they fitted this box in the old 5 series?
Welung666
« Reply #7 on: 18 October 2008, 16:18:52 »
My old 123 series Merc had a filler tube under the bonnet with a dipstick in the middle of the cap. Why didn't VX steal that idea?
Welung666
« Reply #8 on: 18 October 2008, 16:20:04 »
I'd take the sump off anyway, just thought it'd be tidier with a drain plug to empty it first  :y
kris9128
« Reply #9 on: 18 October 2008, 16:45:15 »
tis a fookin stoopid design. so need to drop BOTH sumps off then. will have to wait a little while till got a spare day.  >:( >:( >:(
Welung666
« Reply #10 on: 18 October 2008, 16:49:25 »
Get down your local supermarket and buy a cheapo sack of cat litter, great for soakin' up the ATF after it gets everywhere :y
« Last Edit: 18 October 2008, 16:49:56 by Welung666 »
« Reply #11 on: 18 October 2008, 16:51:26 »
The Senator & Carlton I used to have both had the same thing, as does SWMBO's Astra. I really can't see the thinking behind leaving it off.
Welung666
« Reply #12 on: 18 October 2008, 16:57:33 »
So that VX can charge for an extra couple of gaskets and an extra hour in labour charges ;)
kris9128
« Reply #13 on: 18 October 2008, 17:43:38 »
what a bloody good idea sir  :y :y :y :y
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #14 on: 18 October 2008, 17:56:27 »
i have to say that i didnt do too bad with atf going on the floor, i used one of those old oil tins (the tin ones) and cut the side out and then took all but two opposite bolts off the sump and then let one side down first and then empty the sump bowl shaped thing into the tin lol.. i must admit it's the most messy when there's all the oil dripping from the gasket after... drips for ages!
V8!!!!
