Author Topic: 0500 speed sensor!... Rolling road day???  (Read 1335 times)
« on: 20 October 2008, 18:28:03 »
car felt a bit vibey on tick over so i did pedal trick. And got 0500 speed sensor! Am Presumeing this is abs related and have put it down to the rolling road day a week ago Sunday when the abs and traction controle lights lit up after the dyno confused it.
1 is that correct assumption?
2 i thought the pedal trick only read the engine ecu?
No other codes found, even though i turned on the ignition with the dash out about a month ago. Def correct code i read it about 10 times. Still could be wrong then. :-)
Cheers.
dieseldean
  • chesterfield
Re: 0500 speed sensor!... Rolling road day???
« Reply #1 on: 20 October 2008, 18:48:00 »
paper clip test on my tractor produced 24 vehicle speed sensor. the engine management light did not come on till friday morning and i had to put up with it in a low power limp mode all weekend on my holiday.
« Reply #2 on: 20 October 2008, 18:54:35 »
Yep....cleared it out on one or two whilst I was there!
« Reply #3 on: 20 October 2008, 22:57:00 »
Thanks for re assurance guys,  :y also how come engine ecu is picking up abs issue?   :-/
« Reply #4 on: 21 October 2008, 08:17:44 »
Because it knows it was in gear and it was revving its nuts off.....yet it was told the car was doing 0 mph  :y
« Reply #5 on: 21 October 2008, 12:08:45 »
here is the conclusion,cars must not be clever ;D
