Author Topic: Error Code  (Read 1589 times)
downsmen
  • Kent
    • 2.5 V6 Elite Estate
Error Code
« on: 22 October 2008, 16:44:08 »
Hi can any one help, changed my cam belt after it broke, now it wont start.
Engine Management light on so have done paperclip test and its coming up with 0340
Cheers
Paul
    • 530D M Sport, 330i Coupe
Re: Error Code
« Reply #1 on: 22 October 2008, 16:46:58 »
Camshaft sensor problem, however a 2.0 should still start (with a struggle) as long as the crankshaft sensor is OK  :-/
Re: Error Code
« Reply #2 on: 22 October 2008, 16:55:14 »
Cheers
Paul
What happened when your cam belt broke? :o :o :o
Did it damage any crucial components? :-? :-?
Could be an answer to your current problem ;)
downsmen
  • Kent
Re: Error Code
« Reply #3 on: 22 October 2008, 18:48:56 »
Hi when cam belt broke the engine light came on then it just stopped.
I have not taken the head apart just put a new belt on.
It turns over sluggish but just wont start.
only error code i can see is 0340.
Re: Error Code
« Reply #4 on: 22 October 2008, 18:53:26 »
If the cambelt broke, its very likely you have an engine full of bent valves!
The code is related to camsensor giving incorrect (or no) signal, but that fault alone will not cause it not to start (may turn over 3 or 4 times).
Albatross
  • Bedford
  • An LSD & an S2000!
Re: Error Code
« Reply #5 on: 22 October 2008, 19:02:21 »
Cheers
Paul
Enough said here really. I need add no more than you should probably consider taking the head off to check for damage. The 0340 error message is not your main concern right now.
sev
Re: Error Code
« Reply #6 on: 22 October 2008, 19:15:01 »
As The Boy says, 99.99% chance of a head with three or four bent valves!
The reason for this is that the valves are at an angle to the crown of the piston, so when the belt lets go, it has no choice but to bend.
If the camshaft sensor is registering a problem, it's probably because the bent valves are stopping it from turning as it should.
It would be worth giving one of the breakers on here a pm in order to see if they have a complete head they could send you, all you'd need then is the head studs and a cam cover kit - probably work out much easier than taking the head off, and finding the bent valves, buying new ones, lapping etc.   :y
1995 2.5 V6 CDX Saloon
Re: Error Code
« Reply #7 on: 22 October 2008, 19:49:17 »
And hope and pray that the pistons/bores aren't damaged .. if they are a replacement engine will be needed .. :(
