Author Topic: Can anyone confirm a part number for me?  (Read 1223 times)
retrojim
  • Bedfordshire
« on: 21 October 2008, 21:59:54 »
90298219
Is this the correct part number for the seal for the oil level sensor where the wiring enters the sump on the 2 part sump fitted to 1999 2.0 16V Ecotech engine.
The sensor actually goes inside the sump and the seal is where the wiring passes through the sump wall.
If not - do you know the correct number? Is it the same part number fitted to the V6?
Re: Can anyone confirm a part number for me?
« Reply #1 on: 21 October 2008, 22:04:03 »
Hold fire, let me fire up the VM with EPC on...
« Reply #2 on: 21 October 2008, 22:06:46 »
While you're there .......  ;)
Are Omega face lift screen washer jets the same as Astra G washer jets? please!!  :y :y :y
« Reply #4 on: 21 October 2008, 22:16:59 »
No, Omega same as Calibra and early Corsas
retrojim
  • Bedfordshire
« Reply #5 on: 21 October 2008, 22:20:16 »
Your'e a star!
ALthough it has left me confused! Item 2 is the sensor, item 3 is the o ring I need?  5 is the clip.
Item 1 is ???
« Reply #6 on: 21 October 2008, 22:34:14 »
Face lift washer jets? They're NOT on the bonnet but live on the scuttle. What's on show looks the same.  :-/
« Reply #7 on: 21 October 2008, 22:37:40 »
Ah, I'll check tomorrow.  I'm struggle to type at moment
markey mark
  • SLady bitshorpe north lincs
« Reply #8 on: 21 October 2008, 22:38:19 »
get off the stella jaime  ;D ;D
« Reply #9 on: 21 October 2008, 22:41:15 »
 ;D  ;D  ;D  ;D  ;D
I'm considering moving my PRE face lift washers to the scuttle a la face lift cars. I have a pair of Astra G washers and wondered if they  were the same ..... trying to avoid removing the scuttle on mine  ::)
« Reply #10 on: 23 October 2008, 00:14:39 »
 ;D  ;D  ;D  ;D  ;D
Anyone? ....... preferably not those who've been on the pop!  ;D ;D ;D
