Pages: 1 [2] 3  All   Go Down
Author Topic: Codes  (Read 4095 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
Re: Codes
« Reply #15 on: 22 October 2008, 14:25:42 »
will check and get back.
SP_3.2
  • Leicester
Re: Codes
« Reply #16 on: 22 October 2008, 14:31:24 »
Where would be a good place to look for leaks can not see any so far
Re: Codes
« Reply #17 on: 22 October 2008, 14:34:56 »
Main brake servo pipe.
Plenum to inlet manifold.
SP_3.2
  • Leicester
Re: Codes
« Reply #18 on: 22 October 2008, 15:19:04 »
Just had a recheck and code is
0204
0300
0304
Would that point to one of the coil packs.
    • 530D M Sport, 330i Coupe
Re: Codes
« Reply #19 on: 22 October 2008, 16:43:28 »
Obscure line of thought here.....  ::)
If you've had the camcovers done then the inlet trumpets / fuel rail must have been removed? If so then I wonder if the loom connector is clicked together properly?
Re: Codes
« Reply #20 on: 22 October 2008, 17:24:45 »
P0204 Cylinder 4 injector circuit high
P0204 Cylinder 4 injector circuit low
P0204 Cylinder 4 Injector Circuit Open
Now we're getting somewhere. Looks like it may be a problem with the injector circuit to that cylinder.
Try making sure the multi-way plug clipped to the lifting eye to the rear of the passenger side cylinder head is firmly connected (the larger of the two - smaller connector is crank sensor).
If that looks OK might be worth taking the plenum off and making sure the plug in the injector is OK. While you're there, measure the resistance of the injector - about 12 ohms is typical.
SP_3.2
  • Leicester
Re: Codes
« Reply #21 on: 22 October 2008, 17:41:58 »
Have give it a check and all same ok pluged in well.
Re: Codes
« Reply #22 on: 22 October 2008, 17:50:40 »
Steve...
You say you changed plugs - you would have had to take the coil packs out to do this ?
I don't think it's worth getting 2 coil packs as they won't fail together unless you're hugely unlucky...
I expect it's something simple..
gwa
  • Peterborough
  • Ginger With Attitude
Re: Codes
« Reply #23 on: 22 October 2008, 18:02:37 »
0204
0300
0304
Hmmm, I've been in the position where I got different codes, but with me it was my eyes getting crossed and out of focus as I'm an old git. I suggest you get to your nearest OOF member who has a TECH2 and able to provide a reliable report before spending lodsa dosh. TheBoy did me just fine, saved a bundle. Good luck  :y :y :y
If it ain't fun, it ain't worth doin
SP_3.2
  • Leicester
Re: Codes
« Reply #24 on: 22 October 2008, 20:56:11 »
Is there anywhere else to look as said in the other post by Kevin looks like it could be injecters have check the multi way plug all ok . will look to take off the plenum do the injecters go or is it likly to be just the conection .... :-[ :-[.Running out of time as have to have it up and working by Friday.
Would anyone have any pics of the main parts to check.
Thanks
Steve
« Last Edit: 22 October 2008, 20:56:44 by SP_3.2 »
Re: Codes
« Reply #25 on: 22 October 2008, 21:01:04 »
Will try to pop by on the way home from work tomorrow for 30 mins or so.
Re: Codes
« Reply #26 on: 22 October 2008, 21:02:21 »
Ow yes, with the plenum removed, make sure al the connectors to the injectors are fully home (particularly number 4) as those not so familiar with the V6 often disconnect them when they dont know about the multiplug....and they take a lot of effort to fit back on!
SP_3.2
  • Leicester
Re: Codes
« Reply #27 on: 22 October 2008, 21:06:17 »
Thats great thanks Mark  :y  your a star
PM sent
« Last Edit: 22 October 2008, 21:13:04 by SP_3.2 »
Re: Codes
« Reply #28 on: 22 October 2008, 21:08:38 »
Very good point !!!!
SP_3.2
  • Leicester
Re: Codes
« Reply #29 on: 23 October 2008, 09:32:41 »
Just to check could an air leak from a seal give this and are there any around the injectors..
Thanks
Steve
Pages: 1 [2] 3  All   Go Up
