Pages: 1 2 [3]  All   Go Down
Author Topic: Codes  (Read 4106 times)
Re: Codes
« Reply #30 on: 23 October 2008, 10:05:09 »
Just to check could an air leak from a seal give this and are there any around the injectors..
Thanks
Steve
An air leak could but, your last set of codes sudgest a faulty connection and hence my comment above  :y
Re: Codes
« Reply #31 on: 23 October 2008, 11:48:55 »
Steve mate, you really need to be exactly certain of the codes being flashed out. Make certain you have counted them correctly. Itook a video of mine on my mobile and played it back, pausing when ever i needed, to right down the numbers. Do this a couple of times, to make certain. It can be difficult as it flashes quite quickley, as you may have noticed, also i am thick and cant count anyway. Or maybe get someone to count with you, just to confirm the numbers. You may cost yourself a load of cash/agro for no reason otherwise. But i am sure Mark will sort you out if all else fails. Hope you get it sorted.
Chris
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
Re: Codes
« Reply #32 on: 23 October 2008, 14:05:06 »
Hi Crris
Good point took me 8 times to count them as you say they very quivk and easy to miss count.
Check inj 2 and conection on it was loose. Put back and runing like a dream.
THANK for the help :y :y
Pages: 1 2 [3]  All   Go Up
Page created in 0.024 seconds with 20 queries.
