Author Topic: What controls door alarm buzzer and other bits?  (Read 2305 times)
SteveMJ
  • Hertfordshire
« on: 06 October 2008, 23:08:02 »
My door open buzzer is not operating correctly and my car seat doesn't move (see http://www.omegaowners.com/forum/YaBB.pl?num=1218457248).  I traced the seat cable into the front footwell side covers and I then lose it somewhere behind the dash.  I've looked behind the relays and the fuses but can't see much there.
I looked at EPC but that didn't help me (not sure how I shoudl drive it to get what I want).
There must be something that controls the buzzer and the seat - I can't fathom which though!
Any suggestions appreciated.
S
Steve
Tafty
  • Liverpool
  • This week I am no longer the owner of a miggy!! :(
Re: What controls door alarm buzzer and other bits?
« Reply #1 on: 06 October 2008, 23:20:09 »
not sure on your seat, but the door buzzer could be the door push button having dirty or bad connection. Had something similar on mine a couple of years ago. Just needed the crimps remaking.
SteveMJ
  • Hertfordshire
« Reply #2 on: 07 October 2008, 17:22:57 »
The buzzer buzzes as I turn the ignition off and stays buzzing until I remove the key form the ignition, the interior lights work as expected - so I don't think its as simple as that - nice if it was.
Steve
Steve
SteveMJ
  • Hertfordshire
« Reply #3 on: 17 October 2008, 14:56:07 »
Hi again
I've been away for a week and had the car MOTed, so asked the garage to have a look too - hoping they would have some relavent experience - no such luck.
So, is anyone breaking an Omega so I could try replacing, perhaps, the seat control module and the buzzer.  If so how much?
Steve
Steve
SteveMJ
  • Hertfordshire
« Reply #4 on: 21 October 2008, 12:59:39 »
Another observation I made - when I turned off the ignition today I got three bleeps (sounded like an alarm chirp).  I heard this the other week and thought it was someone elses car alarm.  This doesn't occur every time I turn off.  The alarm is as standard from vauxhall.
Strange behaviour (and frustrating for me too).
Help appreciated.
Steve
Steve
« Reply #5 on: 21 October 2008, 13:12:03 »
Help appreciated.
Steve
I think that's sound of your power sounder's final death call!  ;D
It lives under the plastic scuttle under the wipers on the driver's side.
SteveMJ
  • Hertfordshire
« Reply #6 on: 21 October 2008, 17:55:15 »
Thnaks Andy
I'll have a look around there at the weekend.
Steve
Steve
« Reply #7 on: 21 October 2008, 18:14:24 »
Re your door buzzer. I've never been there with my Omega, but the Senator had 2 contacts on the driver's door - IIRC one was the lights buzzer & the other was more to with powering up the windows when you opened the driver's door. I know the Omega doesn't work quite the same, but opening the driver's door should power the driver's seat via the memory buttons for a short time. Is that some kind of clue????  :-/
Electric problems can be a nightmare to trace. :(
SteveMJ
  • Hertfordshire
« Reply #8 on: 22 October 2008, 18:01:39 »
Thanks for that input Andy.
The lack of seat movement is a mystery at present.
This problem has been bugging me since August - its not bad enough to stop the car running, that why I leave it a while then have another look - it is very irritation.  I bought the car 'cos I liked the extra features; so I want them to work.
I would buy replacement parts - but not a VX prices.  Hence the enquiry about cars' being broken.
Steve
Steve
« Reply #9 on: 22 October 2008, 19:43:56 »
Steve
Have you tried taking the seat out and applying 12 volt directly to the motors via the big connection block ??? Thats how I checked the motors on the old miggy and found one failed ... eliminates wiring problems .... or ... if the motors all work .. confirms them !!
SteveMJ
  • Hertfordshire
« Reply #10 on: 23 October 2008, 17:50:34 »
If I disconnect the data cable (the one with about 20 low power conenections in it) beside the seat, under the plastic cover.  Then if  I reconnect it the seat moves correctly in all directions and the mirrors moves to their memorised position - but only for about 10 mins.
So the seat electro-mechanics are OK.  It seems to me that this is the control that is failing, bearing in mind that the memory is retained correctly.  The door and rear-view mirrors do not move with the memory command when the seat will not move.
Steve
« Last Edit: 23 October 2008, 17:53:01 by SteveMJ »
Steve
